Author Topic: Ugly expansion tank straps  (Read 5426 times)
teahead
  • USA, WA, Des Moines
  • aka "Rob"
« on: July 07, 2019, 18:51:49 »
Anyone know of an outfit that carries new ones?
Can't locate replacements anywhere.
mbzse
Re: Ugly expansion tank straps
« Reply #1 on: July 07, 2019, 19:01:57 »
Quote from: teahead
Anyone know of an outfit that carries new ones?.../...
Yes, your Mercedes dealer
Part No N 900288 122101
I suppose many other vendors in the US supply these as well.
You can also re-finish your originals, zink cad
« Last Edit: July 07, 2019, 20:54:41 by mbzse »
/Hans S
« Reply #2 on: July 07, 2019, 19:03:47 »
What are you after? The straps? I bought new ones from Mercedes dealer. The reservoir - it is a nice DIY job.
teahead
  • aka "Rob"
« Reply #3 on: July 07, 2019, 19:23:11 »
Ya, just the straps.
I'll compare new to re-zinc.
Ya, tank I'm just going to repaint.
Thanks for the part number!
« Reply #4 on: July 07, 2019, 20:46:10 »
The part number suggests it is a standard item: N 900288 122101. I did not detect differences vs. what I had in the car (280SL, March 1970) - but I may be wrong... They are $3 a piece at MB. This is for 113044.
mbzse
« Reply #5 on: July 07, 2019, 20:59:44 »
Note:
I cannot promise that M-B today have not substituted the original type clamps (as seen in the pictures) with something more modern (e.g. worm style). This is something one frequently experiences, when ordering...  :o. Be prepared
/Hans S
« Reply #6 on: July 07, 2019, 21:20:20 »
Yes, this is indeed a danger, as Hans writes - it happens fairly often on items of bigger value.. On the picture is what I got a couple of years ago.
The risk is ca $6 (my geography) in this case for two clamps.
I think I got the same parts as Hans is showing in his post (I just noticed his post now).
What I usually do while ordering parts that are visible: I ask the dealer to notify me if the PN changes because of replacement and if it does, I do not order a part. Works i n 90% of cases.
BTW: the drain hose is not correct for our cars, I think, but I do not care...
« Last Edit: July 07, 2019, 21:43:34 by Pawel66 »
49er
  • USA, CA, El Dorado Hills
« Reply #7 on: July 08, 2019, 00:20:55 »
 Yes, no drain hose was installed on mine at delivery. I put one on as well. :)
1969 280SL 003820
4 speed manual, PS. 77K+miles
« Reply #8 on: July 08, 2019, 01:21:41 »
I bought 2 sets a few years ago and they match the originals.  Re-plating anything rusty can be more trouble than it is worth to remove any pits in the metal.
« Reply #9 on: July 08, 2019, 01:23:34 »
https://www.authenticclassics.com/Original-Clamp-for-250SL-280SL-Coolant-Tank-p/auth-004327.htm
For what it's worth that looks like an original Gemi clamp on the small hose but it carries the wrong screw.  Should be a Phillips pan head screw.
« Last Edit: July 08, 2019, 02:05:50 by Shvegel »
boterinse9
  • USA, IL, marengo
« Reply #10 on: February 05, 2020, 02:00:06 »
Took mine out  buffed the hell out of it  , Looks like a solid brass tank  using  buffing compound  brasso lots of elbow grease  looks beautiful  My ??? is when did they change to that tank can't find the change date..
1970 280 SL Silver Automatic
1976 300D White
2012 C300 4matic
2004 chevy Silverado
« Reply #11 on: February 06, 2020, 13:03:53 »
From the 280 SL change list in PW 25 (from Engelen's book) the plastic tanks were phased in between VINs 20458 and 22306. The metal tanks were brass and painted.
We believe that the last few cars were back to metal.
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
« Reply #12 on: February 06, 2020, 13:51:16 »
I believe Jon's plastic tank VIN numbers approximately translate to Aug 70 to very early Nov 70.
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
MikeSimon
  • USA, OH, North Royalton
« Reply #13 on: February 06, 2020, 14:23:04 »
That should be correct. My car with VIN 22774, late November/early December 70 has a metal tank.
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
mrfatboy
    • Mrfatboy
« Reply #14 on: February 06, 2020, 14:54:50 »
I have seen cars (VIN 22320 & 22326) and both are metal tanks.
"Leute, am Montag wechseln wir zurück zu Metallkühlmitteltanks."  🤣🤣🤣
Signal Red
4 Speed
Iconic
  • USA, IL, Highland Park
  • ex-Membership Administrator
« Reply #15 on: February 06, 2020, 15:59:09 »
For those that don't speak German, I'll save you the trouble of looking it up (that is what I did).
"Guys, on Monday we're going to switch back to metal coolant tanks"
 ;D ;)
1998 BMW M-Rdstr Estoril Blue
« Reply #16 on: February 12, 2020, 00:20:00 »
Regarding the clamps that hold the expansion tank on, mine were pretty nasty some years ago and I was starting the process of trying to get them re-plated.
Then I called Tom Hanson at the classic center and I bought two new clamps from Mercedes-Benz and each was less than five US dollars.
To say it was a no-brainer is an understatement; in fact Tom said better order them now before somebody raises the price!!
