Author Topic: almost ready for swing arm pivot pin  (Read 2432 times)
merrill
« on: July 04, 2019, 00:45:55 »
whew almost ready for the swing arm pivot pin.
i spent about 2 hours getting the swing arm back in place.
it was a challenge getting the rubber o rings to stay out of the way and then align the copper washers, spacers , wedge washers and hanger with mount aligned,
thanks to Charles for his tip to use the conduit as a guide rod.
after i got it all together i was concerned that the hanger bushing was sticking out a little past the pinion mount but of course the rubber o rings are pushing things apart still
hopefully this will all work out tomorrow am when i get the dry ice to shrink the pivot rod and see if i can get this all back together.
« Last Edit: July 04, 2019, 01:16:53 by merrill »
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
Re: almost ready for swing arm pivot pin
« Reply #1 on: July 04, 2019, 05:18:32 »
Hopefully you marked where the flat spot for the pin is located, so you can position it for the installation of the pin.
merrill
« Reply #2 on: July 04, 2019, 17:26:34 »
hi Joe,
sure did!
I got the pivot pin in on the 3rd time, wedge bolt in the first try and the swing arm drive shaft on the first try as welll
stopped while i was ahead
the first 2 try's installing the pivot pin were due to mis alignment of the swing arm or the copper washers.
once i got those straight my guide rod would move smoothly throughout
the dry ice was a mixed blessing today, it was so hot and humid here in Austin that when i pulled the rod out of the dry ice,  it would immediately frost
once i wiped it clean i was able to get the rod about 60% in by hand, from there some firm taps with a block of wood and hammer the rod was fully home.
that was enough for one day for me, stop while i am ahead.
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
clunker
  • USA, NJ, Chatham
  • 1969 US 280SL 4-speed
« Reply #3 on: July 04, 2019, 21:39:57 »
Matt -
Great progress. Be sure to note the required positioning of the boot clamps - see attached from BBB.
Looks like you and I got the same boot clamps
- FYI, if useful for others, got the preferred 9mm rolled edge hose clamps (see an older post from Joe) for the swing arm boot from kartek.com -
  har-70    Norma 70mm To 90mm Diameter Narrow CV Joint Axle Boot Or Hose Clamps 9mm 23/64" Wide        $1.99
  har-68    Norma 100mm To 120mm Diameter Narrow CV Joint Axle Boot Or Hose Clamps 9mm 23/64" Wide        $3.29
--Charles
Charles
1969 US 280SL 4-speed Red/Black
DB9 / 981 S / G300 SWB / CB750 / etc
merrill
« Reply #4 on: July 04, 2019, 21:54:40 »
Charles
hi
thanks !
appreciate the clamping requirement from the bbb.
I was pretty close (attachment)  the small clamp is just about right,   large is close.
I will see if i can get is facing straight down as directed in the bbb
appreciate the input
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
