Author Topic: Can someone explain how these heater levers supposed to work?  (Read 8895 times)
teahead
  • USA, WA, Des Moines
  • aka "Rob"
The Pagoda I'm looking at buying, the blower fan seems inop (Defrost round button not doing anything).
So just wondering what all four slide controls supposed to do (sorry, don't have an owner's manual)?
The picture in the middle seems cryptic and not sure what the red blue black arrows supposed to mean.
teahead
  • aka "Rob"
Re: Can someone explain how these heater levers supposed to work?
« Reply #1 on: June 20, 2019, 22:33:32 »
I assume it controls direction of flow to the defrost ducts above the dash, the side vents, and maybe the floor?
Some combination of the four levers' positions can do each of the above?
« Reply #2 on: June 20, 2019, 23:18:12 »
One of the black arrows points up to the defroster vents in the dash, the other black arrow points down to the floor vents.  The red arrows are for heat.  The amount of heat on the right and left side can be regulated separately.  The blue arrow is fresh air to the floor or defroster vents.  The colored triangles are meant to indicate open or closed, where the wide end of the triangle indicates fully open or on and the narrow tip of the triangle indicates fully closed or off.
The cryptic label is showing the positions of the four levers to achieve maximum defrosting of the windshield.  The fresh air lever (blue) on the upper left left should be all the way to the left (fully open).  The air flow lever (black arrows) should on the upper right should be all the way to the left (up arrow, defrost).  The heat control lever (red) on the lower left should be all the way to the left (maximum coolant flow and air flow through the heater core for heating the left hand side of the car).  The heat control lever (red) on the lower right should be all the way to the right (maximum air flow through the heater core for heating the left side of the car.)
\____ \____
\____ ____/
In the summer, the most effective way to keep the passenger compartment cool would be to keep the fresh air lever (blue) all the way to the left, the air flow lever (black arrows) should be moved all the way to the right (down arrow, floor), and both heat control (red) levers should be moved to the center of the panel (coolant flow to the heater core shut off, and no air flow through the heater core to the vents,).
\____ ____/
____/ \____
The two round vents at each end of the dash are fresh air vents independent of the heater/defroster system.  When the lever below each vent is pointing away from the door the vent is closed; when pointing towards the door, the vent is open and air will flow when the vehicle is in forward motion.
teahead
  • aka "Rob"
« Reply #3 on: June 20, 2019, 23:27:32 »
Thanks so much!
I assume the defrost knob has nothing to do w/defrost but just fan on/off/fan speed?  Is it variable or just two speeds:  HI and LO?
georgem
« Reply #4 on: June 21, 2019, 00:25:48 »
I think you are referring to the diagram which shows the position of the levers. The circular "KNOB" in the middle of the diagram refers to the fan control knob located near these levers (I think it is the one on the right of your picture) - turn it clockwise and the fan blows air.
Good luck with your hunting for a Pagoda
George McDonald
Brisbane
230 Sl
1973 VW Kombi Single Cab Ute
« Reply #5 on: June 21, 2019, 01:11:48 »
Your fan knob is marked "DEFROST" and the fan speed is variable.   When turned fully counterclockwise it is off.  Turning clockwise to the right one can vary the speed from low up to medium, then one click more is high.
« Reply #6 on: June 21, 2019, 02:01:42 »
Keep in mind that the fresh air vent at the base of the windshield needs to be open or very little fresh air ( warm or cold ) will enter your car.
« Reply #7 on: June 21, 2019, 04:49:13 »
These two links should help you understanding the heating/venting controls:
https://www.sl113.org/forums/index.php?topic=12018.msg81775#msg81775
https://www.sl113.org/wiki/Electrical/HeaterControlValve (scan down to the end!)
mauro12
  • Italy, Sicily, Messina
« Reply #8 on: April 13, 2023, 22:05:05 »
Hi guys , I’m curious about one thing . During heavy rain , could be a great idea to close the fresh air lever ( put top left lever to the right ) in order to seal and avoid water under the dash ? This is just my personal curiosity , I was thinking about what could be the reason for a seal for the fresh air cowl vent . Thank you
Mauro Pisani
250sl 1967 5speed zf manual
« Reply #9 on: April 14, 2023, 13:30:46 »
Mauro,
There air intake box should have working drains.
« Reply #10 on: April 14, 2023, 16:49:56 »
These air intake box drains can easily become plugged, good to check them to make sure they are open.
« Reply #11 on: April 14, 2023, 17:04:19 »
My guess is the vent can be closed for the same reasons also in modern cars outside air can be shut off: to prevent smells, polution, diesel fumes or whatever from entering the cabin.
mauro12
« Reply #12 on: May 08, 2023, 19:56:27 »
If you have broken or damaged drain tubes , I believe that if you close the fresh air lever you can prevent water entering into the scuttle box and so inside your car . Correct me if I’m wrong .
Mauro Pisani
