Author Topic: check valve for brake booster  (Read 2221 times)
jb280sl
« on: June 19, 2019, 18:12:57 »
I have had a vacuum leak test done on my early 1969 280SL, chassis 11408, and it appears that I need a check valve that goes between the brake booster and the intake manifold. Does anyone know where I might get this part. My repair place says that it isn't available and I need to rebuild.
rgafitanu@gmail.com
Re: check valve for brake booster
« Reply #1 on: June 19, 2019, 18:30:34 »
Almost any vacuum check valve that fits that hose size will do.
kampala
  • USA, CA, Hermosa Beach
« Reply #2 on: June 19, 2019, 18:41:55 »
Something doesn't seem right.
I thought these were very common and very available.  You certain your shop was referring to this check valve?  This is the one within the line from booster to intake manifold.
https://www.rmeuropean.com/Products/0004313507-MFG4.aspx
250sl - later - manual
280sl - 1971 - Auto - LSD
