Author Topic: Dim Instrument Panel  (Read 6867 times)
Eryck
« on: February 13, 2005, 01:33:16 »
While there is light, my instrument panel is very dim at night. Is this a common problem? Will replacing all the bulbs help?
1965 230 SL White Manual
Hong Kong
Re: Dim Instrument Panel
« Reply #1 on: February 13, 2005, 01:55:26 »
Does the rheostat still work ? This is the small knob that should regulate the intensity of the lights. Sometimes they become faulty or are bypassed altogether. If the problem is not with the rheostat, changing the wattage of the bulbs will certainly have an effect.
« Reply #2 on: February 13, 2005, 07:11:41 »
Eryck,
I think the common perception is that even when using the rheostat to turn the lights up all the way, they are still not as bright as modern cars.  I believe there are light bulb upgrades, search the forum.
« Reply #3 on: February 13, 2005, 08:45:00 »
Does the rheostat dim or increase the intensity of the dash lights?  Mine was intermittent (on/off) at best and had no dimming capability.  Lamps were full on or off.  I had one bad bulb which I replaced.  I also repaired the rheostat.  You need to take the center gauge out.  Repair to the rheostat can be accomplished without removing the glass.  My rheostat (spring) was detatched at one end from one of the terminals.  I was able to solder this end and get the rheostat working again.  I have pics if it would help.
Eryck
« Reply #4 on: February 13, 2005, 08:48:51 »
Thanks, gents, for all the help. Yes, Jeff, if not too much trouble, a couple of pictures will certainly help. Thanks in advance.
Hong Kong
« Reply #5 on: February 13, 2005, 14:48:46 »
Yes, otherwise we would call it a toggle.   ;)
« Reply #6 on: February 13, 2005, 18:09:25 »
Thanks Rodd,
I'm sure you are trying to help.  My question was for Eyrck.  I was trying to determine if he has any dimmer contol at all.  I suppose my previously broken rheostat functioned as a toggle switch since it was either off or on.  It works great now.
« Reply #7 on: February 13, 2005, 21:35:55 »
Sorry Jeff!  I thought it was a general question, not a troubleshooting step for Eryck.
« Reply #8 on: February 14, 2005, 01:18:17 »
I pulled out the center instrument cluster and sprayed some tuner cleaner/lubricant into the rheostat.  The rheostat has worked trouble free for several years now.
Where do you live in HKG?  I just flew back from there and go there all the time.  I am a UPS pilot.
Kevin Keller
Eryck
« Reply #9 on: February 14, 2005, 11:58:49 »
Thanks for all the advice. Gotta be frank with you guys. I don't even know what a rheostat is. But will find out soon!
Hi Kevin,
I live on Magazine Gap Road in the mid-levels.  Let me know the next time you are in town so that I can buy you a beer!
Hong Kong
« Reply #10 on: February 14, 2005, 20:47:30 »
Quote
 It is a mechanically variable ,wire-wound resistor..
