Author Topic: Timing chain  (Read 3390 times)
MP
  • United Kingdom, England, Devizes, Wiltshire
  • 1967 250sl zf 5 speed. colour 172 anthracite
Timing chain
« on: June 04, 2019, 10:18:32 »
Can someone tell me what I do with the timing chain prior to taking off the head so that I don't affect the timing when replacing the head.
Maurice
1967 250sl ZF 5 speed
1991 300ce-24 coupe Sportline
1962 Lambretta TV175/ RB20
2000 Ducati 748s
1970 Ducati Monza
Re: Timing chain
« Reply #1 on: June 04, 2019, 15:19:19 »
Set the engine a TDC "0" with the distributor rotor pointing to #1 spark plug wire. Do not rotate engine until head is in place and chain correctly installed again.
MP
Re: Timing chain
« Reply #2 on: June 04, 2019, 15:59:45 »
Thanks for that but what I need to know is what I do if anything with the chain before I take the head off
2000 Ducati 748s
1970 Ducati Monza
Re: Timing chain
« Reply #3 on: June 04, 2019, 16:41:44 »
I taped it or tied it together with sprocket with the tritit bands (do not know the proper English word). But that was for camshaft removal, not sure if it works with head removal.
Re: Timing chain
« Reply #4 on: June 04, 2019, 20:23:21 »
You do not even need to break the chain. Remove the tensioner, unbolt the camshaft front sprocket and slide the sprocket off with the chain. Remove the sprocket. (note that the sprocket has a front side and rear side because the off-set is different) The unbroken chain can now be attached to a wire and lowered into the gallery so the head can be removed.
MP
Re: Timing chain
« Reply #5 on: June 08, 2019, 09:04:28 »
Thank you both for the information.
Maurice :)
2000 Ducati 748s
1970 Ducati Monza
cfm65@me.com
  • Cape Town, South Africa
Re: Timing chain
« Reply #6 on: June 08, 2019, 11:57:00 »
Maurice,
The sprocket is kept in position on the cam shaft by a woodruff key (a small halfmoon key that slides in the slot) Cover the engine cavity with a cloth or towel to ensure the key does not fall into the chain gallery abyss. Also take note of how the key is inserted into the cam, because there is a slight possibility that it might be an offset woodruff key. If you intend marking the position of the chain on the sprocket, a white Typex pen works just great.
Chris
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
MP
Re: Timing chain
« Reply #7 on: June 09, 2019, 07:21:23 »
Thanks Chris for the good advice
Maurice :D
2000 Ducati 748s
1970 Ducati Monza
