Author Topic: 230SL drum brake cylinder "thrust pin" dimensions? I lost 'em. :-/  (Read 2450 times)
gkrea1
I've successfully lost the brake cylinder thrust pins (#77 in the picture linked below, PN 0004210488).  These are the short rods installed between the cylinder and brake shoe.  One end is a hemisphere and the other notched to receive the brake shoe.  I can make new ones but need:
1) Overall length
2) Depth of brake shoe notch
3) Diameter (8.0mm?)
https://nemigaparts.com/cat_spares/epc/mercedes/1/fg/113042/249/42/001/
I'm a new SL owner and slowly getting up to speed.  This site is an outstanding resource especially the forums and members area.  The car is a 1967 230SL with a 2.5L 129.980 motor (factory replaced) in need of about 20 years of TLC.
-Greg
Montgomery Village, MD
Re: 230SL drum brake cylinder "thrust pin" dimensions? I lost 'em. :-/
« Reply #1 on: January 18, 2019, 22:16:31 »
Welcome to the group!  Is that a '65 Falcon?
gkrea1
« Reply #2 on: January 18, 2019, 23:10:28 »
Hi Mike.  Yes, a good 'ol Ford Falcon Futura.  Not quite sporty but certainly a good cruiser and it loved country roads.  The 302W woke it up nicely without being too much motor.
« Reply #3 on: January 19, 2019, 00:11:13 »
Just in case it is difficult to find this piece at hand, where I see something like you describe is here: https://www.sls-hh-shop.de/main/en/mercedes-230-280sl-w113-/42-brakes/42-a-brake-wheels-
gkrea1
« Reply #4 on: January 25, 2019, 02:16:33 »
Thanks for the link.
I made four "push rods":
40mm OAL (might be a couple mm short looking at the picture in the link)
10mm notch
8mm diameter 1210 steel rod
They're installed and seem to work.  If they are too short I can always make four more!
