Author Topic: Under dash wiring loom routing  (Read 4936 times)
Minerva
  • Ireland, Connaught, Manorhamilton
« on: January 15, 2019, 18:33:05 »
Could do with a bit of help regarding the routing of the wiring loom along the inside of the dash. I'm ok from fuse box to the connectors for the cluster and steering column, I'm fairly sure that there's a bendable wiring tang screwed to the underside of the dash beside the braket for the two connectors listed above, I know where the cluster of earths bolt to(just beside the ignition switch, but not sure whether the loom runs high, as in above the heater controls or low as in under the radio, or whether it runs back near the heater box or out near the front of the dash. I've searched fairly exhaustivly across the forum and the technical manual but cant just get the views i need. Yes I've taken nearly 2000 photos of the rebuild but of course not the exact views!
Any help with pictures of descriptions would be great.
Keith.
Re: Under dash wiring loom routing
« Reply #1 on: January 15, 2019, 22:17:14 »
I know it is not a lot of help, but you may take a look here:
https://www.sl113.org/wiki/Electrical/Rheostat
I do not have anything better at hand...
Minerva
« Reply #2 on: January 15, 2019, 22:56:40 »
Thanks pawel, hadn't seen thst one but had come across this one,
https://www.sl113.org/wiki/Electrical/FlasherRelay
that helped a bit, what I could do with is a picture inside the dash (that shows the loom) with the radio panel removed.
Keith.
« Reply #3 on: January 16, 2019, 12:37:52 »
Thanks a lot Keith...,
Now I understand what you are asking for.  :)
Well, the wiring harness ...
most of the part inside the passenger compartment is located around the inside of the fuse box...; so, around the steering column so to speak.
Therefore, what you already see on the pic you are referring to (that's Alfred's former 66andblue car...  ;) ) is the most prominent section of the inside wiring harness.
The only "stuff" that goes accross the dashboard is the loom that feeds the cigarette lighter, the illumination for the heater levers, the clock and blower motor & switch, the  glove box light and finally the right hand side door contact switch. So, a rather slim arm/branch of the whole wiring harness.
And that one goes just behind (the visible part of) the dashboard, behind/under the radio ... just behind the lower visible chrome strip.
I think to remember there are clamps for sure... So what is visible on Alfred's pic is already part of the loom that goes to the right hand side of the dashboard.
Yes, I do have pictures about this when I disassembled my car 7 years ago ... but it's no longer on my computer ... have to dig deep for this.
Hope it still helps a bit.  ;)
All best & good luck!
Minerva
« Reply #4 on: January 19, 2019, 17:18:07 »
Thanks again Achim I'll route it loosely to see what you think.
Keith
Minerva
« Reply #5 on: January 22, 2019, 11:33:36 »
 Achim or others
Would you be able to tell me which way the loom runs past the dash bracket with the triangular hole in it as per pictures attached.
Thanks Keith
« Reply #6 on: January 22, 2019, 20:29:42 »
Quote
Uhh, Keith....,  :o :o
Now I don't remember that for sure anymore,
it has been almost 5 years ago I did that job. :P
But I would guess it runs between dashboard (that facia you look at from the seat) and between the triangular bracket (the one with the hole)...
.... and not behind.
If you want to put the loom behind the bracket (so, towards the firewall) then please make sure it cannot interfere with the wiper linkage - very important!  8)
The other solution is to look for all the restoration stories the others had here.
How did their's look like before they took it apart. Eric EeeVeePee or so...
Or perhaps one of those restoration stories from motoringinvestments.com
A bit of searching for this appears necessary for this here ....
Good luck
