Author Topic: Koni adjustable shocks for front - PN anyone?  (Read 3517 times)
jameshoward
« on: December 09, 2018, 14:38:41 »
Hi All,
I did a long drive yesterday ostensibly to burn off some fuel to replace with ethanol-free to store for the winter. Driving the car pretty hard at high speeds and with some decent twisting roads, I was reminded how much the car nose dives into corners, and when braking.
I have OEM Bilsteins on the front and Koni Classic adjustable shocks (set at 2 turns) on the rear. I want to replace the Bilsteins with Konis but am confused about the correct PN.
I wondered if anyone had used them and had the correct PN for the adjustable shocks?
Thanks in advance for any advice.
JH
James Howard
1966 LHD 230SL
Peter h
Re: Koni adjustable shocks for front - PN anyone?
« Reply #1 on: December 09, 2018, 20:33:18 »
Yes, it's the big problem if you drive a little faster. I change the spring with Mechatronic and it's much better.
But Mechatronik don't sell them anymore.
I think the original Bilstein for the pagoda are not the big problem.
« Last Edit: December 09, 2018, 21:45:33 by Peter h »
Peter h
« Reply #3 on: December 09, 2018, 21:50:30 »
Yes, I think that's the better way.  8)
MP
  • United Kingdom, England, Devizes, Wiltshire
  • 1967 250sl zf 5 speed. colour 172 anthracite
« Reply #4 on: December 10, 2018, 10:07:05 »
I have Olson springs, they are not cheap but work well, no nose diving and I use standard shocks.
1967 250sl ZF 5 speed
1991 300ce-24 coupe Sportline
1962 Lambretta TV175/ RB20
2000 Ducati 748s
1970 Ducati Monza
« Reply #5 on: December 11, 2018, 18:38:34 »
Sometimes the best answer about [insert manufacturer name] is by contacting [insert manufacturer name].
Thus in the case of Koni, in their current North American fitment guide for the W113:
http://www.koni-na.com/en-US/NorthAmerica/Products/Cars/List/?t=KoniPartSearch&q=1969&m=500&mk=26&mt=1
They only have one shock available: the Special D.
Part number for front: 80-1415
Part number for rear: 80-1416
It is a special order item, thus you may have to search for someone who might have to order it for you.
jameshoward
« Reply #6 on: December 26, 2018, 14:36:48 »
Thank you all for your replies. From what I've read here then, it seems as though I should be looking at springs. I've looked at the Olsen ones and they're bloody expensive. I'll look at the shocks further and will post back.
If anyone has a set of Olsens they're not using and would sell on I'd be interested. I think I'd only need the fronts.
Thanks.
James Howard
1966 LHD 230SL
