Author Topic: how to open the Windshield wiper switch ?  (Read 7191 times)
free2keun
« on: November 21, 2018, 19:17:39 »
Hello Pagode Lovers,
The wiper wont work anymore.  I think (I am sure) it is because the wiper switch wont work.  I have been looking for the mode how to open the plastick wiper switch, but I didn't found.  Can you help me ?
mbzse
Re: how to open the Windshield wiper switch ?
« Reply #1 on: November 21, 2018, 20:06:18 »
Quote from: free2keun
.../...wiper wont work anymore.  I think (I am sure) it is because the wiper switch won't work.../...
What about the wiper relay; are you sure it is working? Common source of malfunction
/Hans S
free2keun
« Reply #2 on: November 21, 2018, 21:22:54 »
There is not coming any electricity from the black/yellow wire to the relay.  But when I make a bridge from the black/purple wire to the black/yellow wire, the wipers works.
free2keun
« Reply #3 on: November 21, 2018, 21:24:23 »
I am talking about a early W113, from 1963
free2keun
« Reply #5 on: November 24, 2018, 17:49:37 »
I Checked all the wires and it is surely the switch that is stuck (shown in the photo).  Can it be repaired ?  Or must I buy a  new blinker system ?  I hope not the last possibility...  ???
« Reply #6 on: November 24, 2018, 18:52:31 »
Look in there: https://www.sl113.org/forums/index.php?topic=18780.msg131242#msg131242
Try search: "wiper switch" or "wiper switch repair" top right corner of the Forum page.
mbzse
« Reply #7 on: November 24, 2018, 18:58:15 »
.../...it is surely the switch that is stuck (shown in the photo).  Can it be repaired ?.../...
Try Alfred's method of removing the pin in order to disassemble, remove the "shell" or "cap" at the end of the stalk.
The halves of the black parts attached to the chrome shaft are permanently joined together.
If you feel adventurous, and you need to do so on your stalk, you can split them along the seam, to aid a repair. The housing (halves) must then be glued together afterwards.
Note that there is an early and a late version of the Pagoda wiper multifunction stalk. The change came about in the summer of 1967 (mid 250SL production)
« Last Edit: November 24, 2018, 19:49:36 by mbzse »
/Hans S
free2keun
« Reply #8 on: November 25, 2018, 19:22:57 »
Thank You Pawel66 for the link.  It helped me a lot to find how to open the cap.
But it is the inside of the cap where the problem is.  how is it possible that the cap not make contact from the left to the right piece ?  Is only a cap for sale ?
Also thank you MBZSE for your input
mbzse
« Reply #9 on: November 25, 2018, 19:39:51 »
.../...  Is only a cap for sale ?.../...
Vendor AMS Hagen has something:
https://oldtimer-ersatzteile24.de/Griffstueck-fuer-Mercedes-W113-Blinkerschalter
/Hans S
« Reply #10 on: November 25, 2018, 22:23:54 »
As usual - a great supplier tip from you, Hans... Thanks!
free2keun
« Reply #11 on: November 26, 2018, 06:04:07 »
Again, thank you mbzse and Pawell66 ! :)
free2keun
« Reply #12 on: November 26, 2018, 06:37:22 »
but how the shift works ?  There are no elements on the inside that move.  How can it put the wiper on en off ?
free2keun
« Reply #13 on: November 26, 2018, 12:20:46 »
So, the switch works again.  Don't ask me how.  I clean the inside with glaspaper en blew in it, and system works, on and off, slow and fast :)
I can't explain :-\
« Reply #14 on: November 26, 2018, 18:11:28 »
You just cleaned dirt that was blocking the current flow? ;) ;)
Congrats - good you made it!
