Author Topic: glove box door curved rod broke off  (Read 3453 times)
merrill
« on: October 27, 2018, 13:33:20 »
well darn,
i was almost done finishing the interior on my car all i had to do was install the glove box.
i was about to set the glove box in place, noticed the glove box door was not opening smoothly when the arm broke off.
i did search the forum and found this post so i appears the rod can be brazed back into place.  (https://www.sl113.org/forums/index.php?topic=21496.msg152963#msg152963)
it loks as if i need to figure out how to separate the 2 halves of the door to get to where the rod is brazed?
any tips would be appreciated
matt
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
Re: glove box door curved rod broke off
« Reply #1 on: October 27, 2018, 13:44:20 »
You will most likely need to re-paint anyway - is it not better to buy a second hand door?
Here is one on ebay:
https://www.ebay.com/itm/MERCEDES-280-250-230-SL-113-GLOVE-BOX-DOOR-LID-230SL-250SL-280SL-CHROME/173596833860?hash=item286b2d7844:g:JE4AAOSwB9xXOjL-:rk:45:pf:0&vxp=mtr
But I am sure the usual ebay sellers may have some of them too. May ask Niemoeller or the store sin the US.
dirkbalter
  • USA, CA, Corona
« Reply #2 on: October 29, 2018, 16:18:36 »
Mine broke at disassembly. I welded it back on and ground the weld smooth. Why are you thinking of taking the halves apart?
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
merrill
« Reply #3 on: October 29, 2018, 19:25:10 »
Dirk
hi,
i thought it was necessary to split the door to re weld.
I took it to a local shop and they are just going to weld it back on for me.  I need to order paint to finish the job.
from my research it appears the rods break off sometimes..   Sucks because I had the box in and took it out. thats when it broke.
I did ask Gernold at SL tech what he does and he said he finds and buys a used door and repaints as needed.
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
dirkbalter
  • USA, CA, Corona
« Reply #4 on: October 29, 2018, 21:01:15 »
Matt
Yes that’s unfortunate. If they are careful with the welding you may only have to paint the inside. . In my case it wasn’t a big deal because everything still gets painted. (Also, and you probable did that, make sure that it is welded in in the correct location.)
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
« Reply #5 on: October 29, 2018, 21:19:28 »
I know it may be obvious, but I will write it:
if I were going to the welders, I would take the complete box with me with the fixed hinge and when they do the "touch" weld, I would fit the door and check if rod goes through the hole with no squeak.
Rosette will fit... it has to go smooth with rosette installed.
merrill
« Reply #6 on: October 31, 2018, 15:56:02 »
Pawel , Dirk
thank you for the tips.
I will make sure to take the box with me when i pick up the door.
i really felt bad when the rod broke off.   but after all of the feedback  i guess it happens.
i will post the results when i receive the door.
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
