Author Topic: New fire wall rubber grommets  (Read 3619 times)
zak
« on: September 13, 2018, 18:38:06 »
I am finally getting around to having the new fire wall pad installed. The one dry original one has been removed and the area under the pad has been cleaned and prepped and ready for pad install. I like the "peel and stick" of the new pad.
My question is on the new rubber grommets. I bought a bag full from Tom Hansen -
Is there anywhere a diagram showing what grommets go where ? Each grommet had an MB part number.
I took photos but want to be sure of proper placement.
jz
1967 250 SL
1983 280 SL
2015 ML 250 Bluetec
2007 ML CDI
2004 E 320 Wagon
1999 E300 Turbodiesel
cfm65@me.com
  • Cape Town, South Africa
Re: New fire wall rubber grommets
« Reply #1 on: September 13, 2018, 18:43:26 »
Hi Zak,
I got my firewall grommets from SLS. Google their site and their images will give you a good idea of where the different grommets should go.
Chris,
Cape Town
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
zak
« Reply #2 on: September 13, 2018, 19:36:13 »
Thank you Chris, I will do that right now.
jz
1967 250 SL
1983 280 SL
2015 ML 250 Bluetec
2007 ML CDI
2004 E 320 Wagon
« Reply #3 on: September 14, 2018, 04:21:10 »
I think I used my EPC (Electronic Parts Catalog or wwhat is commonly reffered to as Startec) to figure out which grommet went where.  If you get stuck on any PM me and I can look them up for you.  In my set there were a few important ones missing so be aware that you may need to source a few more.
Taleb
  • USA, NY, SPRINGFIELD GARDENS
« Reply #4 on: September 14, 2018, 09:48:59 »
Hi ,
If you are in USA ask vintageeuroparts.com if you are in Europe contact Niemoller.de
Good luck
StevenF
  • USA, NY, Merrick
1971 280sl
Red Metallic
Bamboo MB Tex
zak
« Reply #6 on: September 21, 2018, 18:33:30 »
Grommeting underway.
Thank you gentlemen.
jz
1967 250 SL
1983 280 SL
2015 ML 250 Bluetec
2007 ML CDI
2004 E 320 Wagon
