Author Topic: Oil for the fuel inhection pump  (Read 3990 times)
opopotts
  • Canada, ON, Douglas Dees
« on: August 27, 2018, 21:29:03 »
Our 1968 280SL has  s separate oil supply for the injection pump. It has the red filler knob on the top. How much oil does the pump take. I couldn't see any oil in the pump and I put in 1/2 litre and it started to overflow at the back.
thanks
MikeSimon
  • USA, OH, North Royalton
Re: Oil for the fuel inhection pump
« Reply #1 on: August 30, 2018, 20:06:49 »
The fact that there is no response to this question, makes me wonder....
Is there a separate oil supply for the injection pump? I don't see this on my motor.
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
dirkbalter
  • USA, CA, Corona
« Reply #2 on: August 30, 2018, 20:11:39 »
Guys,
take a look here.
https://www.sl113.org/wiki/Fuel/Injection
The earlier ones yes, later ones no.
Hope that helps Dirk
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
« Reply #3 on: August 30, 2018, 20:12:00 »
There isn't. This system is designed to continually drain back into the crank case as the engine is running. Sometimes the drain will get plugged and oil will start to come out the top of the IP. Regardless of system type, this is never a good thing.
1988 560SEC
« Reply #4 on: August 31, 2018, 03:18:27 »
But should Doug's 280 sl's injection pump have a red filler cap on it? Sounds like an older type pump, no?
Tyler S
  • USA, CA, Encinitas
« Reply #5 on: August 31, 2018, 03:31:48 »
The R18 pump was the last to use a self contained oil supply (for the governor section) fill cap, and dip stick. It was replaced by the R20 in early 68. All pumps used an oil feed line from the engine to lubricate the piston portion of the pump.
« Reply #6 on: August 31, 2018, 17:49:33 »
Do you think there's a possibility that Doug's car has the wrong pump installed? It wouldn't be the first time I've seen that.
1988 560SEC
Tyler S
« Reply #7 on: August 31, 2018, 20:07:02 »
That 68 model year is goofy as far as what was installed vs what is supposed to be installed. If someone has the Pagoda Notes with M.Y. changes for 68 it may list when the pump was changed to R20. But yes its possible the wrong pump is installed. The oil line would have also needed to be replaced as its longer on the R20 and installs in a different location on the pump.
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
« Reply #8 on: September 01, 2018, 00:57:49 »
I looked over the Pagoda Notes for 1968 changes.  I didn't  see any mention of the FIP change over.
Perhaps if the OP posts his vin number we could try to isolate if it's an early 68 or late and go from there.
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
mbzse
« Reply #9 on: September 01, 2018, 06:58:56 »
Quote from: mrfatboy
.../...I didn't  see any mention of the FIP change over.../...
It is tied to the new type engine in the 280SL /8; the M130E.
Like Tyler writes this engine was equipped with a new type FI pump
/Hans S
Taleb
  • USA, NY, SPRINGFIELD GARDENS
« Reply #10 on: September 01, 2018, 20:56:42 »
Hi ,
My w111 has the old model pump R11 which I fill up the oil manually and it take about 300ml , but the one on my 280sl pagoda 1969 R20 the oil come from the  engine direct .
It’s seem someone fix the wrong pump on your car , but if it running fine you Must keep it because they are very difficult and expensive to find ...
scoot
  • USA, CA, Altadena
« Reply #11 on: September 02, 2018, 14:16:11 »
thanks
There is a t-handle dipstick that you unscrew at the very back of the pump.  It will show you the level.  Feel around.
Scott Allen
'67 250 SL (early)
Altadena, California
