Author Topic: Repainting rear axel  (Read 3515 times)
CJHenderson
  • USA, AR, Benton
« on: August 27, 2018, 17:29:50 »
What kind of paint is used on the rear axel, high temp or standard paint?
1970 280SL/8 W113 101624 miles.
1950 MG-TD
2021 Harley Davidson CVO Trike
Re: Repainting rear axel
« Reply #1 on: August 27, 2018, 19:37:11 »
I use regular paint. Axle never gets that hot.
CJHenderson
  • USA, AR, Benton
« Reply #2 on: August 27, 2018, 19:47:30 »
1950 MG-TD
« Reply #3 on: August 27, 2018, 20:35:08 »
An automotive grade of black enamel using a catalyst activator resists oil grease and chemicals the best. You can specify the amount of gloss. I think satin black is correct.
steves sl
  • USA, WI, CEDARBURG
« Reply #4 on: August 27, 2018, 21:04:49 »
I use VHT chassis and Roll bar paint. Available at most Auto Parts Stores holds up well. Satin not gloss.
S. Schlaefer
« Reply #5 on: August 28, 2018, 01:21:34 »
I used a black epoxy primer from Southern Polyurethanes.  Designed to be exposed and tough as nails.
« Reply #6 on: August 28, 2018, 15:25:42 »
Looks fantastic!
Sead
  • Bosnia and Herzegovina, Federation of Bosnia and Herzegovina, Sarajevo
« Reply #7 on: August 29, 2018, 17:40:16 »
High-end version I did.
Cink plating + powder coating..
1964 230SL
