Author Topic: Right hand rear axel bearing  (Read 2877 times)
CJHenderson
  • USA, AR, Benton
« on: August 12, 2018, 22:36:55 »
Is it normal for the outer race to separate from the bearing?
1970 280SL/8 W113 101624 miles.
1950 MG-TD
2021 Harley Davidson CVO Trike
Re: Right hand rear axel bearing
« Reply #1 on: August 13, 2018, 00:42:06 »
Completly off or just slid to one side?  It is an odd bearing and the race doesn't stay in line like a ball bearing.  If the race has fallen off completly there is more than likely a way to slip it back on by twisting it all the way to one side and sliding it back on.  If it is an original the cage retaining the rollers is steel so the chance you broke anything is slim.
CJHenderson
  • USA, AR, Benton
« Reply #2 on: August 13, 2018, 01:05:16 »
Thanks you just saved me at least $60. I can reinstall the race and the rollers are fine.
1950 MG-TD
« Reply #3 on: August 13, 2018, 03:36:42 »
That's a good price if you found the right side bearings for $60.00 ?
« Reply #4 on: August 13, 2018, 04:21:59 »
That's what I thought too. $100.00 or more would be more expected.
CJHenderson
  • USA, AR, Benton
« Reply #5 on: August 13, 2018, 13:57:22 »
At SLS for 57.72 Euros
1950 MG-TD
