Author Topic: Correct Head Gasket  (Read 5792 times)
MikeSimon
  • USA, OH, North Royalton
Correct Head Gasket
« on: August 06, 2018, 18:03:11 »
I did a search here but could not find an answer, so, please forgive me if this has been discussed somewhere before...
I am buying parts on-line to put my engine back together after I took the head off.
I bought a gasket set which includes a head gasket as shown in the top picture.
It is different from the gasket I took off which looks like the one in the bottom picture.If I use the one that is supposedly correct, there are a couple of small holes that are not sealed and whatever flows through there would leak into the combustion chamber.
Any words of wisdom?
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
mbzse
Re: Correct Head Gasket
« Reply #1 on: August 06, 2018, 19:00:40 »
Quote from: MikeSimon
.../... but could not find an answer, so.../...
The Technical Manual on this website is your friend.
See here:https://www.sl113.org/wiki/Engine/CylinderHead
/Hans S
MikeSimon
« Reply #2 on: August 06, 2018, 19:49:39 »
Thank you.
From what I get after reading all this for 30 minutes, I have a late 280SL head (which I knew, because of the 22774 serial number of the car).
That means the head casting should be 130 016 1101 and the gasket should be 130 016 5620 "oval", correct?
Does that mean, the gasket I bought was a "square" gasket?
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
mbzse
« Reply #3 on: August 06, 2018, 20:40:04 »
.../...That means the head casting should be 130 016 1101 and the gasket should be 130 016 5620 "oval", correct?
Yes to both
/Hans S
MikeSimon
« Reply #4 on: August 07, 2018, 15:13:54 »
Once again I searched and searched.. and cannot find a source for the correct head gasket. I know, I can always order it from the local MB dealer...any alternatives (preferably cheaper.. ;D)
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
« Reply #5 on: August 07, 2018, 16:16:44 »
I am not sure about the US, in my geography the price difference between MB part and internet stores is about $20 for a headgasket. I would not spend 5 seconds on thinking where to buy (right or wrong, I am not experienced enough to pick a brand for a good gasket). This is not the part I would save money on, unless I knew the brand that is same or better quality vs. offered by MB from someone experienced.
But availability seems to be an issue. I do not see late 280SL gaskets available at MB! Perhaps they hide behind some repair set...
MikeSimon
« Reply #6 on: August 07, 2018, 20:44:23 »
Most internet gaskets I see - although not the correct ones - are made by elring or Victor Renz. Same supplier MB gets them.
And yes, hardly anybody sells a separate head gasket. They all come in sets
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
MikeSimon
« Reply #7 on: August 08, 2018, 12:34:13 »
Head gasket is not available anywhere, from MB to SLS …. Wonder if they will come back with it.
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
« Reply #8 on: August 08, 2018, 15:12:11 »
K & K still has some listed but very pricey.
MikeSimon
« Reply #9 on: August 08, 2018, 16:49:36 »
Where is K & K ???
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
« Reply #10 on: August 08, 2018, 17:54:38 »
Grand Rapids MI.
MikeSimon
« Reply #11 on: August 08, 2018, 18:22:17 »
Thanks all!
I found the access to K&K and ordered an upper gasket set. Supposedly the correct one.
Really surprising thing is, that it was listed at $222.- on the site and I got an invoice for $150.-. Good form, K&K, good form!
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
« Reply #12 on: August 08, 2018, 23:37:51 »
The one I used.  Bought months ago.
MikeSimon
« Reply #13 on: August 08, 2018, 23:43:06 »
It looks like a different part-number. Maybe because it is for oversize bore 87.5 ?
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
« Reply #14 on: August 09, 2018, 01:14:38 »
Hmmm...I never noticed that before.  I checked where I bought it from and they make no mention of bore size.  It is  possible they no longer stock the stock bore or first oversize gasket.  I can't imagine 1mm of gasket hole diameter increase would effect compression or sealing measurably.
https://www.pelicanparts.com/More_Info/1300103521.htm?pn=130-010-35-21-M30
« Reply #15 on: August 09, 2018, 05:34:04 »
Head gaskets are large enough to accommodate max oversize pistons. I believe I have a source for 280SL head gaskets.
MikeSimon
« Reply #16 on: August 09, 2018, 11:51:25 »
That is weird. I have bought from Pelican before and I checked with them also and never found this listed. Wonder what I did?
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
« Reply #17 on: August 09, 2018, 12:20:52 »
What Shvegel is showing (both picture and link) is not a head gasket, but a gasket set.
Not sure if it helps, but to be more systematic and for Mike to identify what he bought:
A1300165020 - cylinder head gasket, replaced by
A1300165620 - cylinder head gasket As of engine.... (late, oval)
A1300164920 - cylinder head gasket, replaced by
A1300165520 - cylinder head gasket Standard And Up To Repair Size I   As of engine.... (same as above)
For gasket kits:
A1300100480 replaced by
A1300103521 - head gasket kit As of....(a bit earlier engine numbers than for head gasket) This is the Pelican link and Shvegel's picture.
I think all of the above are oval.
If you bought one of these sets: A1300100280 replaced by A1300103321 you may be back in square gaskets sets again...
MikeSimon
« Reply #18 on: August 09, 2018, 12:25:11 »
Thanks, Pawel! I did have all these numbers. And the set I bought from K&K indeed is A 130 010 35 21! All should be O.K. now.
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
