Author Topic: Which way to remove pinion tube.  (Read 2768 times)
CJHenderson
  • USA, AR, Benton
« on: July 29, 2018, 16:39:23 »
Which way to remove pinion tube from right axel, remove it by driving it forward or drive it towards the rear? Also I was able to remove the clamps from the rubber boot with out damage, Can I reuse it or will I destroy it when I pull the right axel housing?
1970 280SL/8 W113 101624 miles.
1950 MG-TD
2021 Harley Davidson CVO Trike
Re: Which way to remove pinion tube.
« Reply #1 on: July 30, 2018, 03:50:10 »
I usually drive the tube rearward. Don't forget to remove the tapered pin, and loosen the three cinch bolts.
« Reply #2 on: July 30, 2018, 11:45:09 »
The tapered pin Joe mentioned is key.  Loosen the nut a couple turns and push it out with a hammer and punch. A bress drift would be ideal.  Be nice to it though as new ones are over $100.  Search “tapered pin” if you don’t know where it is.  I recall some recent pictures here.
mbzse
« Reply #3 on: July 30, 2018, 11:51:29 »
/Hans S
