Author Topic: Paint recommendation  (Read 3928 times)
230slhouston
  • USA, TX, Houston
« on: July 25, 2018, 17:08:10 »
In the process of deteming the paint to use. The paint shop and I agree on using Glasurit. He is recommending Glusurit 22 single stage. I was thinking base and clear coat.
Any suggestions/pros and cons?
He is the sourcing 22 line.
Thanks.
Re: Paint recommendation
« Reply #1 on: July 25, 2018, 17:23:30 »
That's what I've used and had good results with it. Base clear gives you a better, long lasting shine, but single stage gives you a more correct look. You decide.
BaronYoungman
  • USA, IL, Joliet
  • Veronica...
« Reply #2 on: July 25, 2018, 17:50:30 »
I have had both done and the base/clear is far superior in long lasting paint jobs.  I would never do a single stage again for a car I intended to use and expose to the elements over a long period.  Just my 2 cents.
Bob "Baron" Youngman
1965 220se coupe restomod
« Reply #3 on: July 25, 2018, 19:18:26 »
I used Glasurit base/clear - very happy. Is there not more polishing opportunities with clear layers on top?
230slhouston
  • USA, TX, Houston
« Reply #4 on: July 28, 2018, 17:38:52 »
Thanks everyone for your reply.
