Author Topic: Need a new exhaust system, UK.  (Read 4617 times)
Paul99
  • 230 SL White. 1966.
« on: June 10, 2018, 17:34:00 »
My centre silencer box gave up today.  The rear box looks good but I notice that my system seems to be one long single part, IE from the headers to the tail pipes.
Seems most come in sections, could it  be a one piece system?
Also, best place to source a new system (mild steel) in the UK please.  1966 230SL RHD.
Many thanks.
cfm65@me.com
  • Cape Town, South Africa
Re: Need a new exhaust system, UK.
« Reply #1 on: June 10, 2018, 18:43:20 »
Hi Paul,
‘All’ the Pagodas had dual pipes all the way to the tail pipes.
However, I have read that some 250SLs had a single pipe, after the down pipes. I don’t really believe that, but my 4th Pagoda, in 40 years, a 250SL, purchased about 2 years ago, came with a single pipe from the down pipes all the way to the tail end.
I hope that someone more knowledgeable could give us the answer.
Chris
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
« Reply #2 on: June 11, 2018, 21:05:23 »
The correct exhaust is an all welded double pipe arrangement made from mild steel and is available from MB.
There are a couple of companies that supply slip-fit stainless steel exhausts but i’ve Never really been satisfied with the fit, especially the down pipes. You also get a different exhaust note.
I currently have a car with a new supplier who makes bespoke stainless exhausts. I will let you know if I’m satisfied with the result.
mbzse
« Reply #3 on: June 11, 2018, 21:32:14 »
Quote from: stickandrudderman
The correct exhaust is an all welded double pipe arrangement made from mild steel and is available from M-B.../...
Some end-to-end pictures and info re: the Pagoda exhaust system here:
https://www.sl113.org/forums/index.php?topic=24399.msg174512#msg174512
/Hans S
Paul99
« Reply #4 on: June 12, 2018, 07:37:18 »
Many thanks for this.  A confusion for me is that on ebay there is a full replacement system, but the supplier says its for LEFT HAND DRIVE cars only?  Were there two types of front pipes? LEFT and RIGHT hand drive?  This one looks very much like my existing one piece system which might be around 30 years old. My car is a 1965 230SL UK car.
Ebay listing here:
http://vi.raptor.ebaydesc.com/ws/eBayISAPI.dll?ViewItemDescV4&item=382334107328&category=61455&pm=1&ds=0&t=1524670773000&ver=0
mbzse
« Reply #5 on: June 12, 2018, 07:47:55 »
Quote from: Paul99
.../...Were there two types of front pipes?.../...
Yes, certainly. On a RHD Pagoda, the exhaust headers face forward to make room for the steering box.
Perhaps before going with the aftermarket Imasaf system, you should look into the
OEM Ebersprächer or Gillet, available via your M-B dealer.
You may want to read about the front pipe crossover boxes as well
https://www.sl113.org/forums/index.php?topic=27708.msg199238#msg199238
« Last Edit: June 12, 2018, 09:29:35 by mbzse »
/Hans S
Mike K
« Reply #6 on: June 12, 2018, 10:14:59 »
I fitted a stainless steel exhaust on my friend's 1969 RHD 280SL which we purchased from Quicksilver (I'm not in anyway connected with them).
Good service and delivery, it was a perfect fit with no complications.
https://quicksilverexhausts.store/products/250-sl-w113-stainless-steel-exhaust-front-pipes-1967-71
If you go this route, you will need to purchase the exhaust fitting kit which is extra:
https://www.sls-hh-shop.de/main/en/mercedes-230-280sl-w113-/49-b-stainless-steel-exhaust-230sl-250sl-280sl/fitting-set-for-249493-496-p-5377
FWIW I also fitted a stainless steel exhaust from SLS, on my LHD '71 280SL , and as Hans commented there's a difference between LHD and RHD exhausts.
Mike
« Last Edit: June 12, 2018, 10:19:28 by Mike K »
« Reply #7 on: June 12, 2018, 10:27:54 »
I was considering IMASAF as I found it on one of the portals here, I figured they were producing exhaust for MB (I think for 250SL only) for some short period of time - but then one of the fellow Members warned me that IMASAF was not a good fit. You may want to search the forum for that.
I switched to chasing the exhaust parts from MB, waiting if something is not available. I hope for the sound to be correct from MB parts and sound is of top importance to me, quite frankly...
KenBourque
« Reply #8 on: June 17, 2018, 18:47:31 »
I believe that the original Ebersprächer is no longer available.  I've replaced mine with the Gilette from Mercedes and am very disappointed with the loud sound it produces.  The Ebersprächer is much quitter.  If you can find an Ebersprächer, please contact me and I will immediately purchase one.  I've been told that the ANSA product is fairly quiet but can't vouch for that.
Paul99
« Reply #9 on: June 22, 2018, 07:47:36 »
Bit of an update.
I wanted to replace my whole system as the one I have looks almost original.    I contacted Classic Mercedes and a couple of other merc suppliers and all said the front down pipes (from the manifolds) for RIGHT hand drive cars are no longer available.  LEFT hand drive no problem.
I ended up replacing the centre and rear boxes and kept the front part in place.  I got the exhausts off Ebay.
https://www.ebay.co.uk/itm/Exhaust-System-MERCEDES-PAGODE-W113-230-SL-CENTRE-MUFFLER-END-SILENCER/382380988577?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
It looks ok but didn't fit exactly.  The existing front pipe seemed too long, (or the ebay one too long!) so needed to cut and sleeve the centre box pipe to make it fit. Sounds good and mild steel quality seems good. Came with all fittings and 2 chrome tail sections as well.
Slight concern that RIGHT hand drive front pipes seem no longer available, unless anyone know where to get them?
Tyler S
  • USA, CA, Encinitas
« Reply #10 on: June 22, 2018, 15:05:39 »
Ken, The Eberspacher Resonator and Rear Muffler are still out there. I was able to find them on various german sites. Here are the internal Eberspacher part numbers in the photos below. They sound good at idle but unfortunately I have not been able to properly test/hear them at run-up due to my issues with the front pipes.
PeterPortugal
  • Portugal, Faro, Lagoa
« Reply #11 on: June 22, 2018, 16:58:08 »
I bought an Ebay Imasaf one for my W111 and can confirm, Like Pawel, that it was NOT a good fit.
1963 220se Cabrio
1968 280se Coupe
Mike K
« Reply #12 on: June 22, 2018, 20:21:30 »
Paul, have you tried  Quicksilver ?
See my comments & link above, repeated here:
Best
Mike
TEJOLX47
  • Portugal, Lisboa, Lisboa
« Reply #13 on: August 06, 2018, 13:16:52 »
Hi Peter,
Did you install the IMASAF?
Did you replace it?
How dis you fix the problem?
Obrigado
Francisco
Francisco
1970 280 SL (US delivered, Auto, AC, PS)
181 Light beige with 423 Tobbaco brown top
PeterPortugal
« Reply #14 on: August 07, 2018, 16:47:45 »
Hi Francisco,
I installed it myself but it took me some time and quite a bit of effort.
If you buy one and get it installed at a workshop they will probably manage it ok.
IMASAF is inexpensive to buy so worth paying the money to give somebody else the headache to fit it !!
I would not say do not buy one but you can obviously buy better !!
1963 220se Cabrio
1968 280se Coupe
WRe
« Reply #15 on: August 07, 2018, 17:03:37 »
I heard from several people that the fitting accuracy of IMASAF exhausts leaves a lot to be desired and needs a lot of ajustment (sawing & welding).
...WRe
