Author Topic: After replacing the fuel filter - expelling air and priming the fuel system  (Read 4298 times)
ChrisZeiss
When one replaces the fuel filter there will be air in the filter housing - How does one expel that air and prime the system so it's full of fuel - and no air ?
Simply prime by letting the fuel pump run (before cranking the engine) - and then crank the engine (and fuel injection pump) until the air is out of the system ? Or is there a better way ?
Thanks for any advice.
Chris Zeiss
Edmonton, Alberta
I would let the pump run for about a minute without cranking the engine to purge the fuel filter housing and fuel return circuit of air.  Then switch off and start the engine normally.  There might possibly be a few bubbles in the line between the filter housing and the injection pump, but not enough air to cause more than a momentary miss or two after the engine fires up.
Kevkeller
  • USA, HI, Honolulu
Not sure if you need to or not but there is a bleed bolt on the top of the filter mount that you can crack open with the pump on until fuel runs out. I’ve done it.
1970 280 SL
ChrisZeiss
Thanks for the tips, Gentlemen !
badali
  • USA, Pa, Butler
  • 1966 230SL
When I changed mine I just started the car normally.  It doesn't take long to get the fuel flowing.
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2022 GLC 300 4 Matic
2025 E53 AMG Sedan
ChrisZeiss
Thanks gents !
I guess I was a bit too worried - just by priming (i.e. switching on the ignition to set the fuel pump running, but not cranking the engine) the filter housing was filled very quickly (within less than a minute) - and the engine started immediately - as y'all indicated.
Dankeschoen !
C. Zeiss
Edmonton, Alberta
