Author Topic: 108 auto tranny in a Pagoda  (Read 5220 times)
cfm65@me.com
  • Cape Town, South Africa
« on: April 14, 2018, 10:34:23 »
Hi Guys,
Do we have consensus that the later model 108 auto tranny will fit in a 113?
The torque converter in my 250SL is leaking and I am considering a later 108 box.
Chris
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
drmb
Re: 108 auto tranny in a Pagoda
« Reply #1 on: April 14, 2018, 21:34:41 »
I have fitted a 108 trans to 3 cars,biggest challenge is making a shifter rod that will clear everything,also the rear mount needs to be modified.The wiring also has to be modified for the different inhibitor switch,and the pressure control rod.A donor car is always handy.
Mercedes Restorer ( retired )
1996 E320 Cabrio
1967 Morris Cooper
Lloydmarx@xtra.co.nz
cabrioletturbo
  • Canada, Ontario, Ottawa
« Reply #2 on: April 14, 2018, 21:52:52 »
Another torque converter, instead? Have new, PM me.
Igor
« Reply #3 on: April 15, 2018, 00:28:54 »
I welded around the rivited hub and around the rivets. Problem solved.
« Reply #4 on: April 15, 2018, 02:56:20 »
Interesting "drmb",  that later transmission is typically smoother and some versions start off in first gear.
cfm65@me.com
« Reply #5 on: April 15, 2018, 06:46:50 »
Thanks Gents,
Much appreciated.
I just hate the ‘3 speed’ gearbox in these cars. I will start collecting bits and pieces to fit a 5 speed Gertag some or other time. Obiously a lot of work going from auto to fitting a BMW tranny.
In the mean time, I’ll have the torque converter rivits welded and live with it for a while.
Thanks for your advice and ideas.
Chris
Cape Town
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
« Reply #6 on: April 16, 2018, 00:25:11 »
Chris,
Also weld the hub to the converter.  The hub is the part the rivits attach to.
cfm65@me.com
« Reply #7 on: April 16, 2018, 05:26:29 »
Thanks Shvegel,
I never gave the hub a second thought, I would only have had the rivits done by a pro welder.
Much appreciated.
Chris
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
cfm65@me.com
« Reply #8 on: April 16, 2018, 17:30:15 »
Hi Guys,
I have been offered two interesting options, 1. A complete 108 manual, floor shift tranny with shifter, flywheel, clutch, etc  and 2. A modern 108 auto box. I have not seen either but are very interested and unsure which way to go.
Question, is the shifter similar to the Pagoda or does the ‘modern’ 108 auto use the ‘modern’ shifter with P forward and then R, N, D, etc?
Chris
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
drmb
« Reply #9 on: April 16, 2018, 18:57:03 »
You can retain the original shifter,just need to make up a rod from shifter to the box.
1996 E320 Cabrio
1967 Morris Cooper
cfm65@me.com
« Reply #10 on: April 17, 2018, 19:18:30 »
drmb,
Did you modify or widen the 113 transmission tunnel in order to fit a ‘modern’ 108 auto tranny?
Chris
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
drmb
« Reply #11 on: April 18, 2018, 01:03:57 »
The tunnel size is OK
1996 E320 Cabrio
1967 Morris Cooper
cfm65@me.com
« Reply #12 on: April 18, 2018, 03:13:09 »
TKS
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
Klaus Pieper
  • South Africa, KwaZulu-Natal, Westville
« Reply #13 on: April 18, 2018, 10:42:02 »
Hi Chris,
When I bought my 1965 230 SL it had a W108 280SE motor and automatic gear box.  The tunnel had been widended, possibly with a heavy hammer, on the left hand side and the opening for the gear change lever had been altered - all fairly easy to reverse.  The propshaft was also shortened.  With a bit of luck I might be able to find photos and if you are interested I could send them to you.  I refitted the 230 SL motor and automatic gearbox a number of years ago and in my (maybe subjective) opinion the 280 SE gearbox resulted in much higher revs and hence a much louder interior with no increased performance compared with the current set up.
Regards, Klaus
cfm65@me.com
« Reply #14 on: April 18, 2018, 20:32:10 »
TKS Klaus,
 Many years ago, I also fitted a 108 280SE engine and gearbox in my 230SL, in order to  keep my SL on the road while rebuilding the engine and gearbox. It must have been a first generation 108, which only required the front section prop shaft to be shortend. It was ten years before the restored engine and gearbox was returned to its rightful place.
I also do not remember any remarkable performance or other mind blowing diferences after either of the swops.
Chris
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
