Author Topic: Tab Washer for Large Fuel Pump  (Read 17014 times)
George Des
Re: Tab Washer for Large Fuel Pump
« Reply #25 on: March 23, 2018, 16:38:43 »
I can not remember the exact dimension I gave them for the thickness but that should not be too diificult to get from an old one. Just make sure yoi specify that you want these done by using th electostatic discharge method. It will produce a much better cut. Ok to use my name. I know they have it on file since I corresponded with them several times during the two runs I had them produce for me. I also found the order sheets for the two different types of motor brushes I had Advanced Carbon Products make up for the pumps. These are exact duplicates of the Bosch produced brushes. I’ll post later.
mrtzmd
  • USA, CA, OCEANSIDE
« Reply #26 on: March 23, 2018, 18:45:36 »
George,
They can't seen to find it in their system. They need the order number from your previous order. Do you think you have it?
I gave them your name and the date along with the file name but they cannot find it. If you like you could send me the email you used to correspond with them and perhaps they could find it that way.
Thank you
Mauricio
George Des
« Reply #27 on: March 23, 2018, 23:46:02 »
I will try to find the correspondence I had with them.
George Des
« Reply #28 on: March 25, 2018, 17:35:44 »
I did find the original invoice and I will send it to you. Send me your direct email in a msg and I’ll get it to you.
George
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
« Reply #29 on: March 25, 2018, 17:38:02 »
I'm in for a few also when you are ready. 👍
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
mrtzmd
« Reply #30 on: March 27, 2018, 03:59:53 »
Thank you George. PM sent.
mrtzmd
« Reply #31 on: March 31, 2018, 04:45:49 »
Just a quick update... They found the previous order and they gave me a quote but waiting for verification that they will be using the electrostatic discharge method that George recommends as the quote does not mention the manufacturing process.
Mauricio
PeterPortugal
  • Portugal, Faro, Lagoa
« Reply #32 on: March 31, 2018, 10:12:34 »
Maurizio,
Thanks for keep moving this forward.
If we want to go the whole way I note that varying thickness shims are shown on the parts list. Does anyone know which dimension is checked to gauge if they are required?
1963 220se Cabrio
1968 280se Coupe
mrtzmd
« Reply #33 on: April 02, 2018, 21:53:36 »
I have a quote for 100 washers at $287.00
Using the edm process.
PeterPortugal
« Reply #34 on: April 03, 2018, 07:58:47 »
I will take 10 Mauricio.
I don't actually need ten so if enough other people want them then I can cut this figure down so everybody who wants one gets one.
If it goes the other way and their are not many takers, I could take 20.
1963 220se Cabrio
1968 280se Coupe
mrtzmd
« Reply #35 on: April 03, 2018, 18:53:58 »
I will go ahead and put the order in. I will let everyone know when the shipment arrives.
Mauricio
dirkbalter
  • USA, CA, Corona
« Reply #36 on: April 03, 2018, 20:15:29 »
I will take 5 Mauricio.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
jeblack123
  • USA, GA, Albany
« Reply #37 on: April 04, 2018, 00:01:37 »
Any tabs not spoken for?
mrfatboy
    • Mrfatboy
« Reply #38 on: April 04, 2018, 00:08:47 »
I'm in for 3👍
Signal Red
4 Speed
PeterPortugal
« Reply #39 on: April 04, 2018, 08:24:06 »
Mauricio,
I am located in Europe but one of my colleagues lives in Miami so that's where mine can be posted.
If emachineshop can post mine direct to Miami it will save you the trouble. Let me know how I can pay you too. I can do paypal or bank transfer.
1963 220se Cabrio
1968 280se Coupe
mrfatboy
    • Mrfatboy
« Reply #40 on: April 04, 2018, 10:58:14 »
There are a couple of vendors(members of this forum) that sell rebuild kits that don't include these washers.. I would think they would want to step up and buy a large lot to add to their kits.
Signal Red
4 Speed
George Des
« Reply #41 on: April 04, 2018, 13:57:03 »
Yeah, I agree regarding the vendors. Those rebuild kits are only marginally useful if you are doing a pump rebuild and happen to have a broken tab washer. When I was assembling these kits, I always included a least one of the original tab washers EMachineshop made up for me sometimes two or three. I am shocked current kit vendors did not figure this out sooner. Just about every long style pump I rebuilt, and it is a lot of them, had a broken tab washer. You simply can not get a good, non leaking rebuild on this pump with a broken tab washer. It is definitely a single point of failure on this pump. Hopefully, this new batch you are ordering will turn out as good as the originals. This is a great service to the members who still use the long style pumps. Now some enterprising member needs to figure out a way to reverse engineer that pesky bellows seal. That was a little beyond my CAD skills and would probably require a trip to eMachineshop to consult directly with them on how to manufacture them. I'm sure they can do it!
George Des
« Reply #42 on: April 06, 2018, 12:16:56 »
Somewhere I also have my eMachineshop CAD drawing for the small woodruff key. Those are a lot less involved to have made up and so less costly, but the dimensions are critical in order that it fits right. I'll post that when I find it if members would like to order those too.
mrtzmd
« Reply #43 on: April 06, 2018, 20:49:04 »
Authentic Classics has agreed to purchase the remaing washers. I will PM all interested members when I receive the washers.
Mauricio
« Reply #44 on: April 07, 2018, 17:46:36 »
I noticed I said “a few” when I put my hat in the ring. I’ll take 5 if that is possible.
mrtzmd
« Reply #45 on: April 08, 2018, 00:26:40 »
Peter,
I apologize for not responding earlier.
You're very welcome, its my pleasure and I admit I need one badly as well. This is keeping me from using the original pump despite having an aftermarket replacement pump on hand.
Since you are in Europe, I would gladly ship them to Miami for you.
Mauricio
jeblack123
  • USA, GA, Albany
« Reply #46 on: April 08, 2018, 03:12:49 »
I would also like 5 if they are still available.
James (Eddie) Black
George Des
« Reply #47 on: May 04, 2018, 14:39:08 »
Did emachineshop ever deliver on these? I recall it took some time on my original orders. Curious as to how well they turn out. The EDM process will result in a much better product.
Kevkeller
  • USA, HI, Honolulu
« Reply #48 on: May 07, 2018, 20:54:19 »
I am wondering if it would be worth it to have impellers for the newer shorter electric fuel pump made.  Does anyone besides me have an interest in it?
1970 280 SL
George Des
« Reply #49 on: May 08, 2018, 13:56:56 »
I am sure they could do it. You would need to have some skills doing the CAD drawing for this or perhaps emachineshop could have one of their staff take an example and do it for you. Be curious as to what they would charge for this as the impleller is a little more complex than a tab washer. Remember, the more you order, the lower the unit cost.
