with our official
Pagoda SL Group logo
from our official partner.
Rear axle alignment tool question ?
Topic: Rear axle alignment tool question ? (Read 4892 times)
erickmarciano
Associate Member
Gold
Canada, Quebec, montreal
January 28, 2018, 04:21:04 »
Hi guys
Trying to adjust the rear axle
1- when we use the tool and put the 2 tubes over the nut the tool has to be rotated around 20 degrees to be able to point on the nut ?? Hope this is clear
2-can we do all this with wheels off the floor ?
1994 E500 W124
1971 280sl
1989 Porsche 930 coupe
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
rgafitanu@gmail.com
Re: Rear axle alignment tool question ?
January 29, 2018, 12:47:31 »
Not really clear what you mean by rotating. The tool goes over the 2 stubs for the trailing arm donuts and it is fixed. The only thing you have to do is to work on the adjuster to bring the differential hinge shaft aligned with the pointer. I have done it with the wheels hanging. I am not sure you can do it with the wheels on the ground.
erickmarciano
Associate Member
Gold
Reply #2 on:
January 29, 2018, 16:23:42 »
I knew It would not be clear lol
To be able to point the pointer on the nut the whole contraption has to be rotated around 20degrees ( the black line 280mm has to go down not paralel to the floor
1994 E500 W124
1971 280sl
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
rgafitanu@gmail.com
Reply #3 on:
January 29, 2018, 20:09:53 »
There must be something wrong. I made the same tool as yours and when I swapped my 4.08 with a 3.27 everything lined up with the tool. I was actually lucky and I didn't need to do any adjustments. So, if the tool is parallel with the car, your pointer is a few inches higher on the diff post (yellow arrow) than where it should be (orange arrow)? Differential is an unusual low position?
erickmarciano
Associate Member
Gold
Reply #4 on:
January 29, 2018, 21:07:58 »
Yes exactly
I will double check this week
1994 E500 W124
1971 280sl
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
rgafitanu@gmail.com
Reply #5 on:
January 30, 2018, 15:13:51 »
Interesting. If the diff. mounting post is correctly bolted to the rubber mount in the trunk the diff. should be at the correct level.
cfm65@me.com
Associate Member
Gold
Cape Town, South Africa
Reply #6 on:
February 03, 2018, 04:08:23 »
Eric,
I think the car should be on the ground. Put it down and roll it a few meters back and forth for the suspension to settle, before using the adjustment tool. With the car in the air, the diff is hanging at an angle
Chris
Last Edit: February 03, 2018, 04:16:40 by cfm65@me.com
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
erickmarciano
Associate Member
Gold
Reply #7 on:
February 04, 2018, 01:03:26 »
Good point. Will lower drive in spring and recheck
1994 E500 W124
1971 280sl
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
rgafitanu@gmail.com
Reply #8 on:
February 06, 2018, 13:08:24 »
There should be very little difference between wheels hanging or on the ground. If the differential mount (new) is installed correctly there should be less than 1/4" of height difference (due to rubber compression). Check that the differential post is fully seated into the mount. Resting the car on the rear wheels may help with seating that mount, I hope.
