with our official
Pagoda SL Group logo
from our official partner.
Backfire
Topic: Backfire (Read 4118 times)
Taleb
Full Member
Senior
USA, NY, SPRINGFIELD GARDENS
Backfire
December 04, 2017, 09:32:59 »
Hi all ,
I fixed new 6 original injectors on my 280sl , ever since the car start backfiring during deceleration, anyone knows what could be the reasons ?
Full Member
Platinum
Poland, Mazowieckie, Konstancin-Jeziorna
Re: Backfire
December 04, 2017, 13:08:24 »
Maybe the engine finally got some fuel through the new injectors?
Too rich now?
Ignition timing to be adjusted?
Plugs/leads?
I am just guessing a bit, do not treat it as potential cause statement - let's see what the others say.
Raymond
Full Member
Platinum
USA, FL, Jacksonville
Re: Backfire
Reply #2 on:
December 04, 2017, 14:28:10 »
Is the car a manual or automatic? There is a switch on manual transmissions that is intended to cut off the fuel flow to prevent backfires on deceleration. Many people disconnect it because it isn't really much of a problem and if it fails it might interfere with normal fuel injection pump operation. How bad is the backfire? Light popping or does it sound like it will blow the muffler off?
Taleb
Full Member
Senior
Re: Backfire
Reply #3 on:
December 04, 2017, 14:47:27 »
hi Rymond , its not bad backfire and the car automatic ...thanks
Taleb
Full Member
Senior
Re: Backfire
Reply #4 on:
December 04, 2017, 14:48:10 »
you are right , lets wait .
Vendor
Platinum
United Kingdom, England, Richmond
Re: Backfire
Reply #5 on:
December 04, 2017, 17:41:37 »
Having fitted the new injectors you did then check the Co didn't you.
Stick
www.colinferns.com
Full Member
Platinum
Re: Backfire
Reply #6 on:
December 04, 2017, 19:59:18 »
GGR
Associate Member
Platinum
USA, DC, Washington
Re: Backfire
Reply #7 on:
December 05, 2017, 07:08:34 »
Backfiring on the intake side is a sign of too much ignition advance or bad valves. Usually happens on acceleration.
Exhaust popping on deceleration is usually a sign of too much ignition retard.
Did you have you ignitiion tempered with at the same time you fixed your injectors?
Backfire
