Author Topic: rebuilt my slave cylinder and made an error...  (Read 4247 times)
erickmarciano
  • Canada, Quebec, montreal
« on: December 31, 2004, 15:33:56 »
I put one of the seals in the wrong way is this important?should I open it up again and rebleed my system?
thnaks
and happy new year
1971 280sl
1962 VW
1954 Allstate vespa
1958 gs150 vespa
1962 gs160 vespa
1994 E500 W124
1971 280sl
1989 Porsche 930 coupe
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
George Des
Re: rebuilt my slave cylinder and made an error...
« Reply #1 on: December 31, 2004, 15:38:34 »
Erik,
 Now I think you really know the answer. Not what you wnat to hear, but the answer is yes. The seals are cupped for a very good reason.
George Des
erickmarciano
« Reply #2 on: December 31, 2004, 16:32:18 »
yes I guess I know the awnser
thanks
1971 280sl
1962 VW
1954 Allstate vespa
1958 gs150 vespa
1962 gs160 vespa
1994 E500 W124
1971 280sl
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
« Reply #3 on: December 31, 2004, 23:54:43 »
The cup usually faces towards the high pressure side. It doesn't mater if you're compressing the fluid or the high pressure fluid is acting against the seals - they face the same way.
The pressure forces the seal out so it contains all the fluid without leaking.
Daniel G Caron
erickmarciano
« Reply #4 on: January 01, 2005, 10:16:05 »
for the slave cylinder I put the 2 cups facing the fluid not one facing the fluid and the other facing the clutch arm . can I leave it this way?
1971 280sl
1962 VW
1954 Allstate vespa
1958 gs150 vespa
1962 gs160 vespa
1994 E500 W124
1971 280sl
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
erickmarciano
« Reply #5 on: January 01, 2005, 10:18:31 »
I put   the 2 seals like this
>> cluthc arm
not
><  clutch arm
1994 E500 W124
1971 280sl
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
