Author Topic: 280SL belts to bypass removed York ac compressor  (Read 3207 times)
clunker
  • USA, NJ, Chatham
  • 1969 US 280SL 4-speed
« on: October 09, 2017, 22:21:23 »
I have uninstalled the original ac system interior unit and the under hood plumbing on my 4-spd 1969 280SL. I now want to remove the York compressor.
I may choose to reinstall ac at a later date (using a Sanden compressor etc), so want to just remove the York unit for now and leave the big AC bracket in place, with the alternator up top.
I propose to simply replace the existing AVX 13x1075 belts that run crank - ac - idler - compressor, with suitably shorter AVX 13x??? belts that run crank - idler - water pump. See pic.
Has anyone tried this approach and know the what shorter belt size should be, or have an opinion on whether this would work ok?
Charles
[correction - V-belt profile is AVX]
« Last Edit: October 10, 2017, 13:31:00 by clunker »
Charles
1969 US 280SL 4-speed Red/Black
DB9 / 981 S / G300 SWB / CB750 / etc
clunker
  • USA, NJ, Chatham
Re: 280SL belts to bypass removed York ac compressor
« Reply #1 on: December 29, 2017, 23:02:32 »
To close this off, if anyone else looking to just remove the old compressor and leave the M-B AC bracket in place:
The (two) belt size required to run round crank - idler - water pump, is AVX13X840.
Charles
clunker
  • USA, NJ, Chatham
« Reply #2 on: January 05, 2018, 19:22:55 »
I mean to mention that by far the quickest and easiest place to get the belts I needed turned out to be vbeltguys dot com.
Charles
