Become a
Full Member
Emergency Contact List
Rear axle rebuilt manual
Topic: Rear axle rebuilt manual (Read 3454 times)
erickmarciano
Associate Member
Gold
Canada, Quebec, montreal
October 04, 2017, 04:21:47 »
Hi guys
My BBB does not have much info on the rebuilt process of the rear axle
Where can I find some printed info?
Erickmarciano@hotmail.com
1994 E500 W124
1971 280sl
1989 Porsche 930 coupe
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
Associate Member
Platinum
USA, OH, Cleveland Heights
Re: Rear axle rebuilt manual
October 04, 2017, 17:39:13 »
How far are you planning on going? "Rebuilding " the axle is really the sum of several jobs performed at one time. Replacing seals, wheel bearings, pinion bearings etc. Most of them have been handled here at one time or another.
erickmarciano
Associate Member
Gold
Reply #2 on:
October 04, 2017, 21:08:47 »
Going all the way lol
Doing or should I say trying to do a full rebuilt
1994 E500 W124
1971 280sl
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
Associate Member
Platinum
Reply #3 on:
October 05, 2017, 01:40:38 »
if your axle isn't making noise I would suggest changing the wheel bearings and seals, the pinion seal and the axle boot (1 piece) those jobs are fairly straightforward. If you Google search "Mercedes Swing axle wheel bearing" I am sure there is info out there. Unfortunately most of the rear axle information is in the earlier BBB. The BBB's are structured so each new issue supplements the one before it. Since the axle dates back to the late 50's you need the earlier BBB. I have the 1959 BB which covers the wheel bearing and pinion seal as long as the split boot repair (I would suggest using the one piece boot).
If you want to go further I will be HOPEFULLY rebuilding my eBay find 3.27 axle in the next couple weeks. I was thinking of doing a write up of the center section bearing change. It isn't super difficult but having proper tools helps a bunch.
