Author Topic: Heater core valve  (Read 4453 times)
vande17941
  • USA, CA, Irvine
Heater core valve
« on: September 27, 2017, 15:47:24 »
I have noticed that my heater core valve isn't closing all the way and needs the little adjustment linkage rids adjusted (the one I can see through the firewall with the rubber plug removed.
It looks like absolute hell trying to figure out how to adjust those heater linkage rods through that tiny hole. Does anybody have any tips or tricks?
'66 USA (1967 model Year) 230sl, 4-speed Manual, Driven Like a Real Car! Set up with KYB Stiffer Shocks, and Motor Mounts w Urethane Inserts Underneath, 3-point Belts, Headrests Installed 🚗
1986 560sl Cabernet & Palomino (not recommended)
2001 SLK320 Sport AMG Silver & Black
  • USA, WI, Mequon
Re: Heater core valve
« Reply #1 on: September 27, 2017, 17:57:53 »
If I recall, pop the ball off the valve and then pull the rod through the hole to adjust?  If not easy to pull, rotate the control in the car.
vande17941
  • USA, CA, Irvine
« Reply #2 on: September 29, 2017, 07:13:56 »
Well I can reach about anything there is in this car....but working through that little hole and getting that thing to where I can adjust it does NOT look fun.
« Reply #3 on: September 29, 2017, 16:22:04 »
vande17941
  • USA, CA, Irvine
« Reply #4 on: September 30, 2017, 14:57:34 »
Great info there...I must have been blind not to find that page. Will give it a whirl, though it doesn't look fun.
« Reply #5 on: October 01, 2017, 16:09:03 »
Believe me the tech manual item is a piece of cake compared to the alternative - pulling out the heater core. I have the bruised knuckles and strained back to prove it. And not only was I a punishment glutton once, I did it twice! Once on my car and once for a friend.
vande17941
  • USA, CA, Irvine
« Reply #6 on: October 01, 2017, 21:01:15 »
Pulling the heater core looks like it would be the most terrifying job on the car? I hope and pray mine never leaks.
