Author Topic: Under dash panel mounting hardware mystery?  (Read 14234 times)
mbzse
Re: Under dash panel mounting hardware mystery?
« Reply #25 on: September 11, 2017, 09:25:54 »
Quote from: mrfatboy
.../... says his March 1968 280sl has screws for the underdash panels
My May 1968 280SL has screws
/Hans S
mclewis
  • USA, NJ, Saddle River
« Reply #26 on: September 11, 2017, 14:20:56 »
My February 1968 280SL (chassis 870) has screws.
Marc Lewis
1968 280SL 728H/728H, 248, 746
2020 C300
2021 E450 All Terrain
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
« Reply #27 on: September 11, 2017, 14:36:43 »
Could this also have a European vs USA model component?
Also, are you guys sure that your cars were not switched over to screws?  Do you have the bracket behind the brake or is the panel screwed into the firewall?
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
« Reply #28 on: September 11, 2017, 17:19:31 »
Hans,
does yours have the holes for the pins in the dash?
Afaik, 250SLs did not have the holes, therefore, this begs the question, when did the holes show up?
mclewis
« Reply #29 on: September 11, 2017, 17:38:32 »
On mine, which is a USA model, the panel is screwed into the fire wall.
Marc Lewis
2020 C300
