Author Topic: Rubber Trim For Bumper Pads.  (Read 5247 times)
ohoraherecaptain
« on: August 18, 2017, 16:51:34 »
Guys, I've spent over an hour searching on line for a small rubber [A Pillar/triangular] trim to fit on to my bumpers. The chrome walls are approximately 1cm thick. The A Pillar/triangular base is flat circa 8cm and about the same height. Because it's this small, it appears to not be very popular. Any of you know where I might find something like this? Only need a meter!
JOH.
Re: Rubber Trim For Bumper Pads.
« Reply #1 on: August 18, 2017, 17:16:12 »
Guys, I've spent over an hour searching on line for a small rubber [A Pillar/triangular] trim to fit on to my bumpers. ...
You must not have searched the site of probably the biggest supplier of aftermarket Mercedes SL parts:
https://www.sls-hh-shop.de/main/de/mercedes-230-280sl-w113/88-b-chrom-anbauteile/1m-profilgummi-stongerhorn-grau-p-2905
« Reply #2 on: August 19, 2017, 02:06:08 »
Here is another source:
http://www.authenticclassics.com/Silver-Grey-Rubber-Liner-Strip-Pad-p/auth-003798.htm
I bought some of this, and it worked just fine. It does take a bit of patience to get it into place, so go slow and steady.
ohoraherecaptain
« Reply #3 on: August 19, 2017, 08:46:40 »
Thanks Alfred.
Actually, I have checked out this site but they don't seem to have the trim I'm after? Appreciate your support.
JOH.
ohoraherecaptain
« Reply #4 on: August 19, 2017, 12:20:35 »
Thanks, Jonny.
I eventually ordered a meter of trim which I hope will do the job. See image.
It certainly is not as easy as one might expect so will update you next week on the outcome.
Total for this Order:       £      8.54
    1   37H9871M
OVERIDER RUBBER SEATING STRIP SOLD PER METRE
£ 0.86   (Taxable)
    1   PO12
ROYAL MAIL SPECIAL DELIVERY(£50+ ORDERS) PRICED BY DESPATCH
£ 6.26   (Taxable)
« Reply #5 on: August 19, 2017, 16:11:24 »
Looks like a different profile to me.
Not sure why you think SLS does not have it in stock; see photo: "Verfügbarkeit" triple green.
ohoraherecaptain
« Reply #6 on: August 20, 2017, 11:34:32 »
Yea, your right Jonny, it is a different profile.
I made contact with a number of rubber companies yesterday and Friday evening. In the process, I became aware that the shape I was looking for is an 'A' frame - with a flat base. The base is the bumpers contact point and the cut/gap/space in the top center is 1 - 2 cm. In a nutshell, the profile is simple, but not that easily sourced.
Surprise, surprise, the original strip can be sourced from a few elite retailers.......... @ 10 times the cost of this one!
The height of this strip is 3cm shorter than the original but it's purpose and design is otherwise the same. If it's not [for some reson] fit for purpose, when I receive it, well - it cost less than a euro, so I'll update on the outcome.
JOH.
« Reply #7 on: August 20, 2017, 15:52:51 »
Most interesting. I have not done the front over-riders on my car so I still have the new pieces. These are the same profile as the original, and are NOT the same as the ones shown in your photo with the number - 37H9871M. As I wrote, I got these from Authentic Classics - the photo from the link I posted still shows as matching the original style.
The photo for the piece that Alfred posted at SLS, is different.
ohoraherecaptain
Re: Rubber Trim For Bumper Pads - Update.
« Reply #8 on: August 22, 2017, 11:30:46 »
Hi Jonny B.
Just in this mornings post, and as I said I'd keep you posted - here's a few pics....
Got a meter strip for less than a Euro & plenty there to fit all four guards. Like the black color as it will chime with the bumper face.
Won't be fitting for another week or so, but I'm now more certain that this will serve the purpose.
Lot's of titbits but getting there.
Cheers.
JOH.
ohoraherecaptain
Re: Rubber Trim For Bumper Pads UPDATE
« Reply #9 on: August 22, 2017, 11:35:52 »
Guess I should have added where I got the strip from:http://www.minispares.com/
Item No:37H9871M
JOH.
« Reply #10 on: August 22, 2017, 17:48:36 »
Excellent - persistence pays off!  :)
Thanks for posting the link.
