Author Topic: Fuel pressure at the fuel injection pump  (Read 3184 times)
srisant
« on: July 31, 2017, 04:27:34 »
Can anyone tell me what should be the proper pressure that fuel injection pump should hold for late 64 230SL?  My mechanic has run some test and my pump only hold 5psi and he suggest this is why the car struggle to have hot start issue from vapor lock where fuel are push out too easy.  Do you think it caused by fuel pressure regulator?
