Author Topic: Oil Filter Seized  (Read 4189 times)
Markbhai
Oil Filter Seized
« on: July 27, 2017, 16:21:26 »
Hi All.
I am looking to change the oil filter on my 66 230SL but I cannot loosen the nut at the bottom of the filter housing, I don't want to present it with unreasonable force, but it just will not budge.
Can anyone offer some advice to a frustrated owner?
I have now removed the filter housing from the engine to gain full access but to no avail.
Mark.
Markbhai
Re: Oil Filter Seized
« Reply #1 on: July 27, 2017, 16:35:32 »
Well... I managed to free the bolt and remove it, but the bell housing is stuck to the top now...does this unscrew?
Mark
mBdrvr
  • USA, PA, Bethlehem
« Reply #2 on: July 27, 2017, 16:44:11 »
I has a rubber gasket that fits in a groove in the container. It crushes onto the fitting when you tighten it. If the long bolt is out , couple of taps with a rubber mallet should loosen it.
Paul
Paul Greenblatt
'70 280 SL
'66 250 SE Cabrio
'60 190 SL
Markbhai
« Reply #3 on: July 27, 2017, 18:14:41 »
Thanks Paul.
That seems to have done it.  It seems that the unit is miising a rubber sealing ring and I think it might have been this which caused the top and bottom to be clamped together...off for new parts now.
Mark.
kampala
  • USA, CA, Hermosa Beach
« Reply #4 on: July 27, 2017, 20:41:21 »
Mark
The rubber seal sometimes hides in the slot in the canister.  You will read that some have missed that it was buried and added a new seal only to crack the canister.  Use a pick and make sure you have removed it.  I would guess it would have leaked crazy if seal was missing.
250sl - later - manual
280sl - 1971 - Auto - LSD
« Reply #5 on: July 27, 2017, 21:07:49 »
Possibly try some heat from a torch to melt the rubber seal and allow the two pieces to separate.
The previous person who was there tightened it too much, possibly with a pneumatic tool.
Walter
Jack Jones
  • Canada, ON, Milton
« Reply #6 on: July 28, 2017, 00:12:19 »
Be careful using a torch on aluminum (aluminium for our UK friends  ;)) parts. A little too much heat and you will be looking for replacement aluminum parts.
Jack
Jack Jones
1970 280SL 4 Speed
1984 280SL 5 Speed
« Reply #7 on: July 28, 2017, 04:33:38 »
I think he is referring to the critical inner housing seal which is missing. It must be in place or the oil will not be filtered.
