Author Topic: Data card  (Read 5122 times)
Taleb
  • USA, NY, SPRINGFIELD GARDENS
Data card
« on: July 22, 2017, 09:22:52 »
Hi all ,
I brought pagoda 1970  Without data card and I'm planning full restoration  it and change the color , is there a way of issuing new data card with the new color or I should keep the original color , where and how to get the new card ?
ejboyd5
  • Southold, NY
Re: Data card
« Reply #1 on: July 22, 2017, 11:51:58 »
Rewriting history, what a novel idea. I wonder what might happen if certain governments around the World tried to do the same.
neelyrc
  • USA, AL, Birmingham
Re: Data card
« Reply #2 on: July 22, 2017, 13:40:33 »
Taleb, the data card for your car is a permanent record showing the details of how it left the factory when new.  If you don't have a copy you can obtain one by emailing a request to Tom Hanson at the Classic Center (thomas.hanson@mbusa.com). Attach a copy of your registration showing your name and VIN number to prove your ownership of the car.
There is not a process to update a data card nor would one want to.  I believe you will need to upgrade your membership status to "Regular Member" to be able to look at our Technical Manual and understand the codes on the data card.  It is well worth the small cost.
I hope this helps.
Ralph
1972 Mercedes-Benz 280SEL 4.5
1988 Mercedes-Benz 560SL
2007 BMW 328xi (E90)
Italy
2004 Toyota HiLux D4D Pickup
Taleb
Re: Data card
« Reply #3 on: July 22, 2017, 22:06:46 »
Thanks Ralph
Re: Data card
« Reply #4 on: July 24, 2017, 20:37:19 »
Taleb,
you can read most of the Technical Manual. Some sections are restricted to Full Members, but 80% is available including the section on Data Cards: https://www.sl113.org/wiki/DataCard/Start
Taleb
Re: Data card
« Reply #5 on: July 26, 2017, 15:26:23 »
thaks ralph
Taleb
Re: Data card
« Reply #6 on: July 26, 2017, 15:28:14 »
thanks peter
smackYYZ
Re: Data card
« Reply #7 on: July 26, 2017, 17:43:37 »
Just a heads up, Tom is no longer handling the data cards. He told me to send the request to classicparts@mbusa.com.
Mike
