Author Topic: Very Hot Automatic Shift Plate  (Read 4069 times)
tarheel
« on: July 21, 2017, 21:26:47 »
Greetings Experts:
I have a 1969 280 SL automatic.
When I drive for approximately 15 minutes, the metal shift plate (chrome piece with gear indications) gets so hot one could fry and egg on it.
Seems to become oddly and extremely hot, and it is hard for me to believe this is normal heat transfer from the transmission.  Gets hot regardless of how calmly or vigorously I drive.
Any thoughts on the cause and solution?
« Last Edit: July 27, 2017, 19:32:01 by tarheel »
PIP1947
Re: Very Hot Automatic Shift Plate
« Reply #1 on: August 05, 2017, 00:07:23 »
Hi Tarheel
I have exactly the same occurrence in my '68 280SL auto, so I am looking forward to hearing any forthcoming explanations. My shift plate becomes extremely hot during hot weather running and is always very warm to hot, regardless of outside temperatures.
Cheers
Pip1947
cfm65@me.com
  • Cape Town, South Africa
« Reply #2 on: August 13, 2017, 06:04:21 »
Hi Guys,
The later models have a light inside the shift plate in order to illuminate the shift gate.
It could be the globe touching the metal shift plate?
Chris
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
« Reply #3 on: August 13, 2017, 13:40:45 »
I had a same thought as Chris. Particularly if you have to drive with some lights on that may be the case.
In Mercedes, in later models, there are 1.2W bulbs to illuminate dash and switches. They are often replaced with a very similar ones, but 2W. I saw switches melted after this kind of replacement. I am saying this just to illustrate that these small bulbs produce a lot of heat...
badali
  • USA, Pa, Butler
  • 1966 230SL
« Reply #4 on: August 13, 2017, 14:02:37 »
There is a thick foam pad inside the housing.  Maybe yours is missing causing the heat to get to the plate.
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2022 GLC 300 4 Matic
2025 E53 AMG Sedan
« Reply #5 on: August 13, 2017, 16:56:17 »
Perhaps you are missing the long heat shield above the exhaust pipes?
