Author Topic: 831.221 Cross reference please  (Read 3547 times)
« on: December 13, 2004, 15:34:14 »
this is the number stamped on head gasket (280sl head marked 280SEL) used on replacement block supposingly 1972...distributors are saying they do not know what it is ...I need this number cross referenced ...I also need exhaust guides and valve seals if anyone has those numbers also.  thanx
Re: 831.221 Cross reference please
« Reply #1 on: December 13, 2004, 16:25:36 »
831.221 is the Elring part no. for the later 130 engine head gasket. They are OE gasket suppliers. MB equivalent is 130 016 5620.
http://www.sl113.org/forums/uploaded/ja17/200441320133_Chart,%20cyl%20head%20and%20gasket%204-13-04.JPG
You will have to see if you need standard or oversize valve guides.
108 050 0624 Std exh valve guide
123 050 0167 Valve stem seal - engine set
The cylinder head and gasket are different from earlier 130 engines but the same valve guides and stem seals seem to be used. Hopefully, somebody here can confirm this.  :?:
« Last Edit: December 14, 2004, 04:25:28 by naj »
