Author Topic: Soft Top Frame Adjustment ?  (Read 6023 times)
gnj588d
« on: May 13, 2017, 10:35:11 »
Has anyone had a problem with the soft top cover chaffing on the
hinge assembly on the soft top storage lid are there ay adjustments
that can be made to move the hood frame slightly away from the lid
hinge to solve this problem,Cheers.Mike.
« Last Edit: May 13, 2017, 10:41:41 by gnj588d »
Paul & Dolly
  • i Car
Re: Soft Top Frame Adjustment ?
« Reply #1 on: May 13, 2017, 11:42:28 »
Hi Mike,
A special Pagoda feature, I think! Happy Chaffe ,
I use four pieces of A4 laminated paper,. Two for the hinges,and.  Two for the. Forward parts of the compartment,this stops the chaffing and damage to the cover seal, and sort top canvas when opening and closing.
There are pictures here if you search for soft top closing, prompt me and I could post them again.
Paul
« Last Edit: May 13, 2017, 11:53:21 by paladin »
Mitsubishi i Car
Toyota RAV 4  Hybrid AWD
gnj588d
« Reply #2 on: May 13, 2017, 12:26:51 »
Hi Paul.Thanks for the prompt reply,the root of the problem lies in the position of the frame
its tight up against the hinge (rubbing) on one side but has a clearance of about 20mm on the opposite side
        Cheers.Mike.
Paul & Dolly
  • i Car
« Reply #3 on: May 13, 2017, 12:49:16 »
Does it fit around the windows, front frame,and rear catch ?
Everything is adjustable, it took ages to achieve a happy compromise between windows,herd top and soft top ...oh joy....
Paul
Mitsubishi i Car
gnj588d
« Reply #4 on: May 13, 2017, 13:40:28 »
Yes it fits ok the front needs a bit of a tug (slightly out of alignment )the windows are ok and the rear clicks into the latch
quite easy .Mike.
mbzse
« Reply #5 on: May 13, 2017, 18:14:10 »
Quote from: gnj588d
.../...problem with the soft top cover chaffing .../...
You do not state what SL you have Mike, but if 230 SL perhaps you miss the wires each side
Soft top interior spring/wire, in German "Stoffabweiser".
See this thread:
https://www.sl113.org/forums/index.php?topic=21178.msg150746#msg150746
/Hans S
gnj588d
« Reply #6 on: May 13, 2017, 19:42:11 »
Hi Hans.My car is a 1966 230 SL the wires and snaplocks are all in place and working as they should my problem seems
to be the frame needs to move over10mm away from the hinge. Thanks.Mike
alpina
    • MBDatacards
« Reply #7 on: May 13, 2017, 19:47:26 »
I covered my hinges with soft black leather. This helps as the roof is not rubbing against rough metal.
Tyler S
  • USA, CA, Encinitas
« Reply #8 on: May 13, 2017, 22:53:29 »
The entire frame is secured and adjusted at its base within the soft top well. There are 2 bolts on each side. Adjustment may help but its possible the top frame is bent.
Mark the current location on the frame mounting points before you attempt an adjustment. That way you can put it back if it makes things worse.
gnj588d
« Reply #9 on: May 14, 2017, 11:44:39 »
Hi Tyler. I was thinking it might be distorted as well, I notice on the technical manual that there should be
two springs each side,  (the large one and a small one) mine just has the large one, the small one is not shown in my parts manual ?
did all 230SLs have them ,what were they for ?.Many thanks.Mike
