with our official
Pagoda SL Group logo
from our official partner.
Fuel filter torque spec-280SL
Topic: Fuel filter torque spec-280SL (Read 3460 times)
stevesoz
April 21, 2017, 18:16:56 »
Replacing the original(brass) fuel filter with the OEM replacement(aluminum) and wondering what the torque specs for tightening are.
Associate Member
Platinum
Canada, ON, Port Lambton
Re: Fuel filter torque spec-280SL
April 21, 2017, 18:18:20 »
None that I'm aware of. If it leaks, it's not tight enough.
1966 230SL 5 speed, LSD, header pipes, 300SE distributor, ported, polished and balanced, AKA ''The Red Rocket ''
1970 3.5 Coupe
1961 190SL
1985 300CD Turbo Coupe
1981 300SD
2013 GMC Sierra
1965 230SL
stevesoz
Reply #2 on:
April 21, 2017, 18:22:34 »
Pretty easy to over tighten aluminum threads and have them strip out!
Associate Member
Platinum
Reply #3 on:
April 21, 2017, 20:18:11 »
I think the pipe inside the housing is steel so it shouldn't strip the threads. Fuel will leak out of a very small opening and that's why you might need to keep tightening until it stops leaking.
1970 3.5 Coupe
1961 190SL
1981 300SD
2013 GMC Sierra
1965 230SL
