Please check out joining the
Emergency Contact List
for help during your travels!
Tool to adjust steering box play - Will an angle grinder pin wrench do the job?
Topic: Tool to adjust steering box play - Will an angle grinder pin wrench do the job? (Read 2856 times)
GGR
Associate Member
Platinum
USA, DC, Washington
February 26, 2017, 14:49:27 »
Hi all,
I tried to adjust the play on the steering box of a friend's car. But the second nut on top of the box is so tight against to round flange that the whole assy turns and I couldn't find a way to block the flange so as to loosen the nut. I remember someone mentioning an angle grinder pin wrench to hold the round flange. Here is an adjustable one:
http://www.ebay.com/itm/Adjustable-Pin-Wrench-15mm-x-80mm-Angle-Face-Spanner-for-Rotary-Grinder-Polisher-/111818694417?hash=item1a08e9df11:g:ylEAAOSwI-BWPk11
Before ordering it I would welcome any tip and experience in this regard.
Thanks!
twistedtree
Full Member
Gold
USA, VT
Re: Tool to adjust steering box play - Will an angle grinder pin wrench do the job?
February 27, 2017, 08:35:17 »
I haven't tried that, but it seems like a viable option. I used a pair of right angle needle nose pliers. It was not a fun job.
1964 MB 230SL
1970 MB 280SL
2023 BMW x3
