Author Topic: Hard Top Securing Post Removal  (Read 7517 times)
JimVillers
  • USA, VA, Virginia Beach
« on: February 06, 2017, 23:18:47 »
I am restoring my hard top and need to remove the door jam securing post.  The manual says to remove the pin with a drift.  I have tried that but mine seems very solid.  With the plastic cone, I can't seem to get any kind of support while I try to drive it out.
Has anyone successfully removed these posts?  Any advice?
Jim Villers
Re: Hard Top Securing Post Removal
« Reply #1 on: February 07, 2017, 00:28:17 »
Hi Jim,
did you remove the sleeve as described by Gernold in the tech manual? "To remove the lower release handle shown in Figure 4, carefully grind away the tapped end on one side and remove the sleeve which is pushed over the pin. If you are unable to drive out the pin with a center punch, use a drill."
I had to grip the sleeve with a vise grip (see marks in the photo) to drive the pin out.
Since you have to destroy the sleeve make sure you have a new pin available. Either just a straight pin:
http://www.authenticclassics.com/Hardtop-Latch-Pin-Fits-230SL-250SL-280SL-113Ch-p/auth-007026.htm
or the sleeve and pin from a member:
http://www.ebay.de/itm/W113-Mercedes-Pagode-Hardtop-Verriegelung-B-Saule-230-250-280-SL-/332091941090?hash=item4d5238e0e2:g:nlwAAOSwDN1URCqL
Note that only the sleeve and pin are included NOT the other parts (cone and spacer).
« Last Edit: February 07, 2017, 00:38:50 by 66andBlue »
Jordan
  • Canada, ON, Jordan
« Reply #2 on: February 07, 2017, 01:43:58 »
Jim, I removed mine about a month ago.  Used a centre punch.  The one side came out reasonably easy but I had to spend a few days applying penetrating fluid and banging on the second one to finally get it to move.
Marcus
66 230SL  Euro 4 speed
JimVillers
« Reply #3 on: February 07, 2017, 03:05:05 »
Now I understand.  I knew that there was more to this than met the eye.
Thanks and thanks for the links.
Jim Villers
JimVillers
« Reply #4 on: February 07, 2017, 19:36:16 »
One more question; there was a sealant between the trim pieces and the steel top that looked like "plumber's putty".  Is that the correct sealant or would 3M strip caulk or a seam sealer be better?
Jim Villers
« Reply #5 on: February 07, 2017, 19:44:15 »
Jim,
When using the punch and hammer.
Try to align the direction of the hammering force to the back of the hardtop, i.e. turn the handle so that the pins are parallel to the side glass and the one with the press fitting towards the front.
This method reduces the vibration and bending/distortion of the fragile steel frame that holds the side glass in.
Best of luck.
Walter
StevenF
  • USA, NY, Merrick
« Reply #6 on: February 07, 2017, 21:28:11 »
1971 280sl
Red Metallic
Bamboo MB Tex
« Reply #7 on: February 07, 2017, 23:20:33 »
Jim,
50 years ago Daimler actually did use "plumber's putty" made with linseed oil but you cannot get it any longer. 3M strip caulk is OK, I have used "Mortite":
https://www.sl113.org/forums/index.php?topic=22952.msg164087#msg164087
Walter's suggestion for hammering the pin out is very necessary if you do not want to take the glass out. Otherwise take the glass out first as Gernold describes it.
