Author Topic: my engine turning tool  (Read 2937 times)
lurtch
  • USA, CA, Santa Rosa
  • " ICON 66 "
« on: January 28, 2017, 00:02:38 »
Hey All,
This works great.  I drilled  a hole through a 80mm 15 flat oil filter wrench.
It fits perfectly inside the crankshaft pulley. Sliding cheater onto the 1/2 inch ratchet gives you better mechanical advantage.
Larry in CA
Larry Hemstreet  in  N. Cal.
1982  300TD-T (parted out)
1986  560SEC (totaled)
1991  300TE (gifted)
1998  E320 (sold)
2004  E320 wagon (gifted)
2008  CLK550 Cabriolet
Re: my engine turning tool
« Reply #1 on: February 08, 2017, 16:53:19 »
I did one too, but not so sophisticated and a little difficult for short precise shaft turns:
1. Took some wires, fuse, momentary switch, clip and a pin for connectors
2. Put the wires, clip, pin, switch and fuse together
3. Clipped one wire to battery +
4. Put the pin into cold start relay connector plug, connection no. 86
That was the easiest way I could think of. But precise turns are difficult.
