Author Topic: Pilar A part?  (Read 7301 times)
cstinchi
Pilar A part?
« on: December 22, 2016, 01:51:21 »
HI Guys,
Before I took my pillars A to re-chrome I took a picture of the whole thing to make sure I would assemble correctly. Just a question on the picture below...what is this triangle part and why do we need to use it?
Thank you in advance.
Caio
cabrioletturbo
  • Canada, Ontario, Ottawa
Re: Pilar A part?
« Reply #1 on: December 22, 2016, 03:11:25 »
It is a part of the vertical chrome piece on your A pillar. It is not a separate piece.
I believe rubber seal is leaning against it when properly installed. Not sure of its practical use.
Igor
cstinchi
Re: Pilar A part?
« Reply #2 on: December 22, 2016, 05:58:24 »
Thank you Igor.
Re: Pilar A part?
« Reply #3 on: December 22, 2016, 06:57:23 »
It is a part of the vertical chrome piece on your A pillar. It is not a separate piece. ...
Sorry Igor, it is indeed a separate piece with the p/n 1137250141 and is used in other locations also.
See my reply #18 here: https://www.sl113.org/forums/index.php?topic=17459
Re: Pilar A part?
« Reply #4 on: December 22, 2016, 12:15:35 »
And wait until you find out how much Mercedes will charge for it!
cstinchi
Re: Pilar A part?
« Reply #5 on: December 22, 2016, 14:09:27 »
Thank you Alfred. It did resolve my problem.
Happy Holidays to all!
Caio
cabrioletturbo
Re: Pilar A part?
« Reply #6 on: December 22, 2016, 17:20:48 »
Thanks Alfred, you are right. I did not notice it could be separated. Things you learn every day, thanks to the fellow members.
Igor
A1137250141
« Reply #7 on: December 22, 2016, 23:59:55 »
Quote
The little triangles are inconspicous but very necessary. These protect the window seals from getting out of its guide rail (chrome strip) while the door window squeezes against the seal.
Especially the lower edges of the window seals will come out easily with the years if this supporting 'triangle' clip is missing. :D
Ask me how I know .... ??? :P
(still has to buy some of these very expensive clips)
cstinchi
Re: Pilar A part?
« Reply #8 on: December 23, 2016, 05:04:50 »
Thank you Achaim,
It makes total sense.
Happy Holidays!
Caio
