Author Topic: Putting a rearvision mirror on the passanger side  (Read 8513 times)
col320ce
« on: December 18, 2016, 12:10:52 »
Have many people done this on the 230SL? If so did you make it line up with the other mirror or did you place it slightly further towards the back of the car for better visibility?
I have 2 right hand side mirrors and eventually (not yet) I will be in the market to swap one for a LHS mirror. (both mirrors are genuine, not after market).
Thanks for any comments ...
Col
1964 230SL
1965 250SE coupe
1993 320CE Sportline
cfm65@me.com
  • Cape Town, South Africa
Re: Putting a rearvision mirror on the passanger side
« Reply #1 on: December 18, 2016, 13:00:19 »
Hi Col,
If I remember correctly there is a difference between a LH and RH mirrors for the LHD and RHD cars.
The passenger side mirror needs to turn much more 'in' towards the driver than the drivers mirror. Therefore the LH mirrors for a LHD and RHD differ as does the RH mirrors for the RHD and LHD cars.
I am not sure if this is true for the early Pagodas(230/250SL) or the later(250/280SL) ones, but it is worthwhile to check.
Chris
Ps. You will also find the passenger side mirrors are much more expensive than a regular drivers mirror
« Last Edit: December 18, 2016, 13:04:34 by cfm65@me.com »
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
Rolf-Dieter ✝︎
  • Canada, ON, London
« Reply #2 on: December 18, 2016, 13:24:54 »
Hi Col,
From what I've read on this subject is that most members here feel that adding this mirror is fairly useless. Also we don't need it on 2 lane highwayays were we do most of our cruising and on express ways we normally stay in the slow lane anyway. At one time I wanted to add a passenger mirror myself then gave up on that idea.
Dieter
cfm65@me.com
« Reply #3 on: December 18, 2016, 13:44:30 »
Hi Dieter,
I must agree with you. However, it is very usefull if you own and drive a lefty in a RHD country, as I do, but then you must have the correct mirror and in the correct position.
Chris
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
gimp
« Reply #4 on: December 18, 2016, 19:53:09 »
Hi Dieter
Following you to Williamsburg I do not remember you spending much time in the slow lane :) :)
Frank
« Reply #5 on: December 18, 2016, 20:14:06 »
Col,
The second mirror must be slightly further back.  Don’t ask how I know but if they are both the same position then the left hand one does not get much of a look behind as it is blocked by the A pillar somewhat.
You need to find one that is correctly fitted and measure how far back it is from the door lip.
« Reply #6 on: December 18, 2016, 20:33:22 »
I have the mirror, and it's in the same position, relatively speaking, as that on the driver's side. The only issue with it is it isn't easy to adjust (leaning over with the window open) when static, impossible when moving.
I should note that a few years ago, for a small fee, I bought from the classic center the convex mirror glass and put it in BOTH mirrors. Makes both more usable.
« Reply #7 on: December 19, 2016, 02:29:53 »
Michael, note that Col has a 230SL. Those swan neck mirrors cannot be at the same relative position.
Col,
here is a pertinent discussion about 230SL mirror location:
https://www.sl113.org/forums/index.php?topic=19721
georgem
« Reply #8 on: December 19, 2016, 06:37:17 »
Col,
Ihave a rhd and I added a passenger mirror.
I am away from the car at the moment but if I remember it sits the same distance away from the glass but further back. I put masking tape on the door with a line to represent the centreline of the mirror. I sat in the driving seat and my wife moved it until I had clear vision. She marked its position.
I dont think there is any "genuine" position. Remember that the door skin is aluminium so you will need a good backing late. There may be a plate in there already for when its lhd but it wont be of any use.
Because the glass is flat and fairly small, the view isnt panoramic but set correctly it helps. A cooperative passenger is a must to adjust it
George McDonald
Brisbane
230 Sl
1973 VW Kombi Single Cab Ute
« Reply #9 on: December 19, 2016, 07:52:56 »
What I do to adjust the passenger side mirror 'solo' is kneel on the passenger side beside the car, at 'ride height', then adjust the mirror until I can see the headrest (which is where my head will be when driving). Works pretty well.
merrill
« Reply #10 on: December 20, 2016, 16:29:03 »
hello
when my father purchased his 230sl in Germany the passenger side mirror was mounted up on the right front fender.
maybe that was before the convex mirrors were available....
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
Rolf-Dieter ✝︎
« Reply #11 on: December 20, 2016, 17:14:51 »
Smart approach for adjustment Cees, makes a lot of sense !
Merrill, that must not look very nice.
Dieter
col320ce
« Reply #12 on: December 20, 2016, 21:09:01 »
Thanks for everyone's input
I think I will try someone holding it at 72mm back from the front edge and use this as a starting point:
"The DRIVERS side is 62mm from the leading (front) edge of the door to the start of the chrome base, and the PASSENGERS side is 72mm. That is the chrome not the rubber gasket." ---- from the post 66and Blue linked.
I'll also look into getting some convex glass for both too as this sounds like a great idea.  And I'll post a wanted/to sell add to see if anyone has an original LHD drivers mirror they want to swap for an original RHS driver mirror.  :)
Thanks again ...
Col
1964 230SL
1965 250SE coupe
« Reply #13 on: December 20, 2016, 23:59:14 »
You really only need the mirror stem as everything else is the same on either side.
col320ce
« Reply #14 on: December 24, 2016, 23:38:22 »
One on order! I've also located some convex mirrors so Ill see how it all goes....
Thanks everyone
Col
1964 230SL
1965 250SE coupe
« Reply #15 on: December 25, 2016, 00:06:27 »
Col,
Where are you getting the convex glass for the mirrors?
col320ce
« Reply #16 on: December 25, 2016, 00:44:12 »
http://m.ebay.com/itm/141297058375?_mwBanner=1
EBay... I'll let you know what they are like
Col
1964 230SL
1965 250SE coupe
col320ce
« Reply #17 on: December 27, 2016, 11:08:42 »
Are you doing the MBCV Sl run in Feb?  If the car is in one piece I might be there .... hopefully they will be on the car by then ...
Col
1964 230SL
1965 250SE coupe
« Reply #18 on: December 27, 2016, 14:28:46 »
 I am in Tasmania for a week 24 Feb to 4 Mar so am going to miss that one.  I will probably be doing the Sunday 19th concourse day, not entering but just attending.
