Author Topic: Windows washer water pump mounting  (Read 4448 times)
col320ce
« on: November 26, 2016, 15:25:51 »
Should the windows washer water pump be mounted vertically or horizontally.  Mine is vertical and works when it's primed but if I try to use it the following day it doesn't seem to move the water as the 'gears' are spining in air.
I assume this is a positional thing.
Any pictures of it in a RHD 230SL as I'm not sure where it goes if it's horizontal.
Thanks for any help...
Col
1964 230SL
1965 250SE coupe
1993 320CE Sportline
cfm65@me.com
  • Cape Town, South Africa
Re: Windows washer water pump mounting
« Reply #1 on: November 26, 2016, 16:06:29 »
Hi Col,
The washer pump is mounted horizontally.
If you look under the General Discussion section, about 3 posts down is a post re Hemmels restorations. They have a nice picture of the engine bay of a LHD which should give you an idea. Mine is unfortunately also LH. However, someone is bound to send you a picture if you cant figure it out.
Chris
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
Tyler S
  • USA, CA, Encinitas
« Reply #2 on: November 26, 2016, 18:55:52 »
Either way it is mounted, air can get into the system if the washer bottle level is lower than the pump. A check valve can be added to the end of the washer hose in the bottle to keep it primed.
« Reply #3 on: November 26, 2016, 21:33:04 »
This is mine on a ’65 230SL RHD
« Last Edit: November 26, 2016, 21:37:16 by Garry »
col320ce
« Reply #4 on: November 26, 2016, 23:11:21 »
Awesome info!
I'll re mount mine and try to source a check valve.
Col
1964 230SL
1965 250SE coupe
col320ce
« Reply #5 on: November 27, 2016, 05:42:40 »
All mounted horizontally and working well.  I've ordered a 4mm  check valve so hopefully this makes it work instantly each time...
Thanks as always...
Col
1964 230SL
1965 250SE coupe
