Author Topic: Help Unplugging Connect On Tail Light Bulb Holder  (Read 5149 times)
rbouch8828
  • USA, MA, Framingham
  • 280SL Mfg date AUG 1969
« on: November 16, 2016, 18:05:15 »
I am trying to unplug the center connector from my right rear tail light bulb holder. The other two connectors were easy, but the one in the center is not. Is there a locking mechanism? This is in a 1970 280SL.
Many thanks,
Roland
« Last Edit: November 17, 2016, 15:00:46 by rbouch8828 »
RB
mmizesko
  • USA, OH, New Albany
Re: Help Unplugging Connect On Tail Light Bulb Holder
« Reply #1 on: November 17, 2016, 15:11:33 »
Roland,
Probably just corroded.  no lock. try to pry it with a screwdriver GENTLY.
Mike
1970 280SL 291H Dark Olive
« Reply #2 on: November 17, 2016, 16:34:21 »
Be careful, I think there is a locking mechanism of sorts. Where you have the arrow pointing on the long side, I think that has to come out just slightly to clear the sides of the second piece.
rbouch8828
« Reply #3 on: November 17, 2016, 17:15:58 »
Thanks, I tried using a screwdriver, but couldn't get it to move.
RB
cfm65@me.com
  • Cape Town, South Africa
« Reply #4 on: November 18, 2016, 11:28:34 »
Hi Roland,
I have attached a few photos of the cover you are battling with. You should be able to see the barbs holding the cover in position.
Chris
Cape Town
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
rbouch8828
« Reply #5 on: November 18, 2016, 15:23:55 »
Hi Chris,
Thanks very much. Somehow, I managed to slide the top cover off then pull out the base and after that, slide the top back on.
I don't know if I damaged the "barbs" you pictured in the process, or not. From your photos, I'm not sure where they attach to the plug.
RB
