Author Topic: 230sl cylinder head  (Read 4213 times)
srisant
230sl cylinder head
« on: November 02, 2016, 13:56:09 »
Hi, I have to replace my cylinder head, wondering if 220SE cylinder head will work perfectly with 230SL head? If not what will be alternative?
Re: 230sl cylinder head
« Reply #1 on: November 02, 2016, 16:14:23 »
250SE/SL is your only other choice.
« Reply #2 on: November 02, 2016, 20:28:02 »
Yes, Dan is correct.  The 220SE head has no provisions for injectors. The 220SE has injectors mounted on the intake manifold.
srisant
« Reply #3 on: November 02, 2016, 23:26:48 »
If I use 250 head is it going to impact engine performance or it will be the same?
« Reply #4 on: November 03, 2016, 07:09:53 »
It might even be a bit better due to slightly higher compression ratio and larger intake valves of the 250.
