Author Topic: Exhaust Valve diamter 230 SL ??  (Read 5735 times)
« on: November 10, 2004, 06:37:29 »
Anyone have the diameter of the exhaust valve on a 230SL, actually the stem size ?
In fact I need to ensure I have the right exhaust valve seals, so even the correct exhaust valve stem seal internal diameter ??
'03 CLK Kompressor
Re: Exhaust Valve diamter 230 SL ??
« Reply #1 on: November 10, 2004, 08:27:01 »
Ben,
Don't have sizes to hand but here are Elring part #s for the stem seals which may help:
253.693 exhaust
022.233 inlet
174.750  engine set.
Klaus
« Reply #2 on: November 10, 2004, 09:06:10 »
Tabellenbuch 1969:
valve stem diameter 8,948....8,970 mm
Klaus
1969 280 SL
« Reply #3 on: November 10, 2004, 12:29:32 »
In my '66 databook, Klaus's figures are for an inlet valve.
Exhaust valve stem: 9.928....9.950
Valve guide inner dia:  10.000....10.015
Klaus
« Reply #4 on: November 10, 2004, 14:18:37 »
naj is correct, I looked at the intake valve.
Klaus
1969 280 SL
« Reply #5 on: November 11, 2004, 04:03:46 »
Thanks guys this is what I wanted and confirms I still dont have thr right seals. The internal diameter of my seals is 9.0mm !!
'03 CLK Kompressor
« Reply #6 on: November 11, 2004, 13:06:26 »
You can replace the exhaust valve guides with 280SL sytle and then use 250/280 valves and hardware. Much easier to get parts and the seals won't pop off.
Daniel G Caron
« Reply #7 on: November 12, 2004, 02:48:29 »
Ahhh yes good advice Dan.......I wish I'd thought of it when I did the head last year !
At the moment I am just trying to overcome the problem of a few seals popping off !
Thanks folks !
'03 CLK Kompressor
