Author Topic: air filter housing installation  (Read 10656 times)
col320ce
« on: September 09, 2016, 01:42:17 »
Hi
Has anyone got a picture of the correct way so seat and secure the air filter housing? It looks as though what I have may not be correct.
Thanks for any help ...
230sl 1964 man
Col
1964 230SL
1965 250SE coupe
1993 320CE Sportline
gorgoo
  • France, Île-de-France, Epinay sur Orge
Re: air filter housing installation
« Reply #1 on: September 25, 2016, 07:17:45 »
And sorry, I don't have the answer... but the same question for an Euro-spec 280SL.
I know ther setup I had when buying the car was incorrect but can't find the correct one, so if someone also has the information for a 280SL.
By the way, it'd be worth confirming ther are 3 different air filter as suggested by the Niemoller catalogue https://www.niemoeller.de/en/w113/w113/B042/090/
And also if LHD and RHD cars have the same.
Didier
« Reply #2 on: September 25, 2016, 10:35:24 »
Didier
The air filter on the right of the picture (12) is an oil bath filter specially ordered for dusty road conditions.
All other cars would have the filter with the paper element (1)
LHD and RHD cars use the same filter AFAIK.
« Reply #3 on: September 25, 2016, 10:37:19 »
Hi
230sl 1964 man
Is your air filter 'oil bath' or 'paper element'?
I think the base locating rubbers are not the same...
col320ce
« Reply #4 on: September 25, 2016, 10:47:57 »
Hi naj
It's a paper element... RHD...
Col
1964 230SL
1965 250SE coupe
col320ce
« Reply #5 on: November 27, 2016, 05:56:45 »
I finally took out the air filter to show what my set up is... Feels wrong as it wobbles around a bit.
Thanks again....
« Last Edit: November 27, 2016, 06:03:52 by col320ce »
Col
1964 230SL
1965 250SE coupe
« Reply #6 on: November 27, 2016, 16:18:19 »
I have a 250 SL and the mounting bolt with the bit of surface rust, in the depression toward the fan is there. But my car does not have the hexagonal metal "pad", nor is there a depression for that "pad" buffer. There is a mounting point on the inner wall of the fender. See second post.
« Last Edit: November 27, 2016, 21:18:48 by Jonny B »
« Reply #7 on: November 27, 2016, 21:06:04 »
Here are a few shots to illustrate. This is the mounting in my 250 SL
I took advantage of your question to take a close look at mine, and ended up pulling it out to clean up around that area. It does get dirty.
After re-assembly it is rock solid. The are only the two attachment points as shown in the photos. Air cleaner 1 and Air cleaner 2 are the same point just different angles. It is attached to the inner fender well.
I took a quick look at the 230 SL parts book (C edition) and the 250 SL book. The air filter housing shown for the 230 SL is different from the 250 SL housing. There is a second rubber buffer on the 230 SL part, but it is not listed with a separate part number and appears to be a part of the housing itself?
Neither book shows the attachment hardware at the fender well. Although you can barely see the other mounting bracket for the 250 SL filter in the parts book.
« Last Edit: November 27, 2016, 21:17:03 by Jonny B »
« Reply #8 on: November 28, 2016, 02:36:48 »
And here are the two mounting points for my filter in the RHD 230SL.
Hope that also helps together with Jon’s photos
280SE Guy
« Reply #9 on: November 28, 2016, 09:38:12 »
One of the mounting studs is broken as noted by the red arrow.
col320ce
« Reply #10 on: November 28, 2016, 11:28:14 »
Looks like mine is the same as yours ... I think ... so looks like it might be correct. Maybe it is supposed to have a bit of wobble in it as the engine will move around a fair bit when driving the car.
Thanks again ...
Col
1964 230SL
1965 250SE coupe
« Reply #11 on: November 28, 2016, 13:23:19 »
I don't think the air filter should move at all. Any engine wobble should be taken up by the flex hose from the air filter to the intake manifold.
badali
  • USA, Pa, Butler
  • 1966 230SL
« Reply #12 on: November 28, 2016, 13:28:18 »
I replaced all 3 mountings on mine.  The one that is causing your wobble is the broken one 280SE guy pointed out.  The mountings are still available and fairly cheep...
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2022 GLC 300 4 Matic
2025 E53 AMG Sedan
WRe
bogeyman
  • USA, NE, Omaha
« Reply #14 on: November 28, 2016, 15:23:43 »
On my 280 there is an angle bracket that bolts to the inner fender. With that fastened it shouldn't move much.
Rick Bogart
1969 280SL Silver(180)/Green
1993 500E
1972 350SL
1995 E320 Cabrio
col320ce
« Reply #15 on: November 30, 2016, 12:36:13 »
Gary
In you second picture is this an attachment point, or is it like mine being more like a shock absorber with the rubber resting against the metal stop?
Thanks!
Col
1964 230SL
1965 250SE coupe
badali
  • USA, Pa, Butler
  • 1966 230SL
« Reply #16 on: November 30, 2016, 15:25:26 »
It's not a metal stop.  Your mount is broken...
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2025 E53 AMG Sedan
280SE Guy
« Reply #17 on: November 30, 2016, 15:29:52 »
I guess the old saying "you can lead a horse to water but you can't make him drink" applies here.
« Reply #18 on: December 01, 2016, 06:27:59 »
As Brad said, your mount is broken.  It bolts on either end and it appears on your photo that the rubber has broken away from the mounting bolt.  You can easily get a new mount from Mercedes Centre California.  Call or email to Tom Hansen thomas.hanson@mbusa.com who will give you a bit of a discount to our members and post it to you. It will be cheaper that way rather through a local MB dealer.
col320ce
« Reply #19 on: December 01, 2016, 08:01:14 »
Thanks everyone...  I'll order the part.
Sorry for being so dim.
« Last Edit: December 01, 2016, 10:16:40 by col320ce »
Col
1964 230SL
1965 250SE coupe
