MB simply doesn't operate like that. However, they are very capable of stubbornly holding on to some very anal policies.
Cainboy56,
I can only fully support what Benz Dr. said.
In those days deviations from the normality (like missing chrome strips or so) where almost impossible by the factory. Unless it was a car specifically prepared for a show or Daimler-internal purposes or so.
The datacard would clearly point this out (Code 998 or equivalent together with the relevant built order document).
If you don't find those special codes:  "fuggetaboutit"! A 60ies Mercedes is
NOT a 1930ies Lincoln or so.
Most likely the many preowners changed something in an "aftermarket"-like style.
Check your car carefully and you will find the holes for the missing chrome strips "filler-ed" in.
So, let's see what you have:
Color, white, underside of trunk painted white.  Rockers are car color.  Side trim, only the lower section, 3 pieces, no pieces above only
folded metal. (I have seen this on only a few early cars)  Under doors only the long inside trim piece, the flat rubber and no outer trim
piece. (Place for the piece but never installed)  Wheel wells, rough material, dark grey.
Color white:
 -> ok, Code 050 or 717 on the datacard. See here:
http://www.sl113.org/wiki/DataCard/DataCardsUnderside of trunk painted white:
 -> Incorrect. Should be black.
Scratch off some of the paint there; you will find some remaining black underneath. And some remnants of the primer paint runs.
Rockers are car color:
 -> Incorrect. Typical sign of poor repaint quality where the shop (or the owner) did not know about the specialities of original Pagodas. Again: scratch off some white paint and you will find black/dark grey underneath
-> Also incorrect. The brass chrome is surely missing on your car. Have never seen this on serial cars. On pre-series/prototype cars, yes, but not during serial production. Clearly, the holes had been plugged. Look closely from the inside. You
will find 'em.
piece.
-> Clearly missing. Sounds to me as if once your rocker panels were replaced in the past - most likely due to rust issues or so. If you take them off you should be able to find the little holes for the old/previous sheet metal screws that held on the outer chrome strip under the door.
It is under restoration.
-> Very good. Then you can correct these faults now. Or have them corrected.
Good luck.
(done a lot of research on original cars)
