Author Topic: Another Factory Sunroof Car  (Read 6126 times)
Tyler S
  • USA, CA, Encinitas
« on: August 09, 2016, 01:17:54 »
This thing is pretty rough. Fred Flinstone would be envious. I am wondering if a resto would even be worth it but the potential that its a true factory sunroof car may set it. I wonder if the seller would disclose the body number for research purposes. The vin is listed in the add.  A pic of the hardtop body number would be the key in all of this. If its not a factory sunroof car and the top is "mismatched" then the top itself would be worth far more than the car. The Landau material peeling off makes me suspicious but you never know.
http://ebay.com/itm/272334091068
« Last Edit: August 09, 2016, 01:32:12 by Tyler S. »
su8pack1
  • USA, PA, Barto
Re: Another Factory Sunroof Car
« Reply #1 on: August 09, 2016, 01:56:44 »
 :o Wow.
1984 300CD
1987 190E 2.6
1988 190D 2.5
« Reply #2 on: August 09, 2016, 06:18:19 »
Reserve not met at $6,000 whereas the condition is a close tie with that one that was recovered from the river Neckar ...
Challenger_7
« Reply #3 on: August 09, 2016, 10:54:34 »
You must have the nerves of steel to go into such a project  ;)
I have gone through many restorations to have the patience any more, and have no clue as to the value of a true sunroof Pagoda.
But by all means if your are serious about this, you need to ask for the body number as well as the hard top number to do the homework properly, and if he does not supply them, I would pull on my brakes!
Good luck
« Reply #4 on: September 06, 2016, 00:13:27 »
The layer of pink body filler ringing the sunroof opening as well as the factory grey primer disappearing around the opening tell the story to me.  Unless the sunroof cars were farmed out to another vendor to be installed i would run from this one.
68_white
  • USA, TX, Houston
« Reply #5 on: December 17, 2016, 20:12:27 »
This thing is back on ebay. Has anyone checked to see authenticity if sunroof?
HARRY
1970 280SL RED
2002 E430 SILVER
1996 911 BLUE
Tyler S
« Reply #6 on: December 17, 2016, 22:13:08 »
Its back on and up to 18k with reserve not met.
http://ebay.com/itm/272481754528
« Reply #7 on: December 21, 2016, 02:13:27 »
If you see pictures of a genuine sunroof car the roof resides just inside the chrome rails on the top. This one is too wide.
« Reply #8 on: December 23, 2016, 03:54:44 »
Here's a factory sunroof.
