Author Topic: Removing window spring  (Read 4048 times)
CJHenderson
  • USA, AR, Benton
« on: August 07, 2016, 20:03:04 »
How do I remove window spring? Window is fully retracted but spring has a lot of tension
1970 280SL/8 W113 101624 miles.
1950 MG-TD
2021 Harley Davidson CVO Trike
Re: Removing window spring
« Reply #1 on: August 07, 2016, 20:15:59 »
I've done this auccessfully by holding the end tightly with pliers (I think vicegrips) and using some muscle stretching the spring enough to get it past the catch and off.
CJHenderson
  • USA, AR, Benton
« Reply #2 on: August 07, 2016, 20:22:25 »
Ok thanks I'll give it a try
1950 MG-TD
« Reply #3 on: August 07, 2016, 21:16:10 »
Is the window lifter still in the door?
It is easier to remove the spring when the lifter is out.
CJHenderson
  • USA, AR, Benton
« Reply #4 on: August 17, 2016, 02:13:38 »
It's out thanks
1950 MG-TD
Pinder
  • USA, NJ, Edison
« Reply #5 on: August 17, 2016, 02:37:45 »
I've used sheet rock screws to safely remove the springs on my soft top frame. basically screw them in to each thread section until spring expands then it should be easier to remove it. you may need 10 or 20 screws to stretch it.
2015 BMW 320i xdrive
2021 Mercedes GLS450 Silver
